FS hypex ncore 2x250W
Hello
For sale a 2 x 250 watts Hypex NCORE NC252MP in black anodised aluminum case.
This unit is BRAND NEW, fully tested, and will be covered with 1 year warranty from Hypex.
Case fits inside one Hypex Ncore NC252MP amplifier stereo module 2 x 250W with built in power supply in a compact power brick.
Specs here: http://www.hypex.nl/product/nc252mp-oem/76
Main SMPS Power supply is an auto switching P.S. (115 / 230VAC) and rated to 650W max. Will work form 115 to 230 VAC.
Hypex only sells Ncore MP series to OEM resellers, that’s the why they are different to the rounded "public" Nc400 series.
The amplifier is an Ncore class D amplifier intended for ultrahigh-fidelity replay systems with flat frequency response irrespective of load (from 2 Ohm to 8 Ohm) and High efficiency (92%) with low output impedance and very low noise.
Ncore is the first Class-D amplifier not just to nudge the best linear amplifiers, but to surpass them in every aspect relevant to sound quality. If you want the ultimate in clarity, resolution and musicality, there is no longer a reason to trade efficiency or compactness.
Sound becomes smooth, effortless, powerful, deep, resolving. Broad and deep soundstage with that amazing feeling of "closiness" of musical experience. Bass is amazingly
controlled and deep.
No resistive losses, no EM/RF radiation, perfect current flows between PSU and amp. What is more, it is Dead silent - no hiss at all. Complete immunity against any interferences from on-board SMPS.
Some features:
Peak Output Power (1KHz, THD=1%): 180W @ 2Ω, 250W @ 4Ω, 200W @ 8Ω
Distortion (THD+N): Typical: 0.0020% Max: 0.006%
DC Offset protection.
Power Bandwidth 20-35kHz
Frequency Response (+0/-3dB. All loads.) 10-50kHz
Voltage gain 26 dB
Input XLR connectors SWITCHCRAFT INC (USA)
Output binding post ELECAUDIO (made in France)
Silver output wires and solders
External dimensions 230x280x80mm (WxDxH)
Full black anodised aluminum front, rear and side pannels. Black iron top and bottom.
Weight 2,8 kg
Asking 650€ + shipping + paypal fees
Pictures are from the units on sale
paginas imagenes
Hello
Some features:
Voltage gain 26 dB
Weight 2,8 kg
paginas imagenes
Why do you sell it then ?
