Muses Volume Attenuator Kit
Amount: max. 5
Price: 2-Ch (single ended) 77€, 4-Ch (sym.) 125€
Shipping: Calculate by destination
Features:
- 35mmx35mm
- 2,4,6,8 channels possible because volume boards can be cascaded
- 0dB to -111.5dB/0.25dB and mute function
- 20kOhm input impedance
- Operation / mounting on rotary encoder with switch function
- Save current volume as startup volume
- +/- 15 V voltage supply
- Controller is in "no operation" state out of function, all clocks are off in order to avoid
disturbances of the audio signal
- Volume +/- and Mute remote control (RC5, RC6, NEC, Apple ...) incl. learning function
https://www.dropbox.com/s/qt4uxrzfmxoo8n7/Muses Volume Control English.pdf?dl=0
The Kits are dull assembled and tested. Only the rotary encoder is not assembled (shipping reason).
Shipping include IR Receiver.
Received my volume control thanks!
I have a couple of questions:
1. Do you think it will be any benefit running separate 5v power to digital part?
2. Have you tried using display recommended in the manual? If so can you provide a link where one can get it?
Thanks.
well, if you done some testing and have some conclusions made I might gladly believe you and save some time 🙂.
Thanks for the link! As for galvanically isolate it, I just use separate PSU, or need to make some circuit?
Circuit
