Audio Nirvana Super 10 Ferrite Fullrange Spkrs-Pair
These drivers are in near perfect condition. The rear magnet decals were removed because the adhesive was not bonding to the magnet. These only have a few hours use and never made it into cabinets. Only selling these to move up in the Audio Nirvana line to the 15-inch drivers.
$195/pair + shipping
Google speaker designer Les Hudson and Audio Nirvana on Audio Asylum. Les states that these are the finest drivers he has ever tested in an open baffle design.
Will be shipped FedEx Ground, double boxed in their original packaging.
From the AN Web Site:
SUPER 10 inch Series with whizzer cone/phase plug, Ferrite Magnet
The Audio Nirvana 'Super 10 FERRITE' has a test bench frequency response from 34 hz to almost 20,000 hz (varies by temperature). You can expect at least 99 db efficiency in any of our cabinets. It handles 30 watts continuous RMS (normal listening level will be about 1/10 watt). Impedance is 8 ohms. Voice coil is 1.4 inches (35.5mm). Magnet weight is 3.2 lbs. Total weight is 9 lbs. The cone is made of paper. The surround is accordion style and made of treated cloth. The phase plug is copper anodized, machined solid aluminum.
