30+lbs of unmarked toroids - diyAudio
Go Back   Home > Forums > Commercial Sector > Swap Meet
Swap Meet Sell your stuff here, who knows, some other fanatic might be interested!
Old 21st March 2017, 05:29 AM   #1
Default 30+lbs of unmarked toroids
I have no use for them nor do i have any test gear to determine the primary voltages (assuming most all are designed for an American customer I'm sure the primary is 115v) or the secondary voltages, some are heavy duty big transformers for big tube projects some slightly smaller for solid state designs.
Willing to let the whole lot (15 transformers last i checked for $125, and I'll split shipping, would prefer to ship to West coast residents.
Open to trades for raspberry pi 5v plug-n-play low noise power supplies and 24v, 3+ amp smps for my amp camp amp.
Old 21st March 2017, 06:18 AM   #2
DPH is offline DPH  United States
Hey Zachary, might not hurt to say whereabouts you are on the West Coast, as there are lots of members up and down the coast (myself included), whom might be within driving distance. Having just moved, 125 lbs is no joke to ship.
And if you're close to Portland, I might be interested (and able to measure said secondaries)
Happy DIYing, Daniel
(This space is occupied by the artist formerly known as Derfnofred)
Old 21st March 2017, 06:20 AM   #3
Close to Sacramento California.
Old 27th March 2017, 11:47 PM   #4
BWRX is offline BWRX  United States
diyAudio Moderator Emeritus
Do you know who manufactured the transformers? If you don't have a multimeter it would be wise to invest in one, then you could easily measure the secondary voltages. Some more info would go a long way to helping you sell them.
Brian
Old 27th March 2017, 11:50 PM   #5
Some are unmarked, some are by Toroid, some talemas. What would I measure with my multimeter?
Old 28th March 2017, 01:59 AM   #6
The wire gauge can give you an idea of the maximum current ratings, and some basic measurements can get you the unloaded secondary voltages and an estimate of the turns ratio. Transformers will have higher secondary voltages at no load. If you aren't sure about the primary voltage ratings you should reduce the AC voltage being fed to the transformer primary under test to be safe (unless you're sure they are 120V rated primaries). You can use a variac or a known 120V rated transformer to do this. With the primary (or primary windings in parallel) connected to the reduced AC voltage you can measure the primary and secondary AC voltages to get the approximate turns ratio.
Brian
Old 28th March 2017, 07:18 PM   #7
sl1 is online now sl1  Slovenia
As far as I know trafos are basically about the ratio between two windings. you can apply any voltage (ok not megavolts) and according to the ratio a higher or lower voltage will show up at the other end.
So if you want to measure them, just put in 110V or whatever is convenient for you (just measure the input exactly) and measure voltages that come out on secondaries and make a list. By knowing input and output voltages you know the ratio and hence where you can use this trafo. You can use the same trafo in 110V and 220V world, it just depends for which the secondary voltages are useful.
If you measured them and sold them individually, you could make at least twice the money. But it is some work with measuring, shipping...
Unmarked Iron Core Inductors THUMP LUMP Multi-Way 33 15th February 2017 03:11 PM
found some unmarked Kenwood speakers are they worth it? cerius Multi-Way 5 8th April 2015 02:49 AM
Aleph 30 unmarked resistors? kasra Pass Labs 11 18th April 2012 06:27 PM
Matching a TK2050 to Tony Gee LBS Billyo Class D 11 23rd April 2011 01:46 AM
lbs VS kilos and pounds demogorgon Everything Else 21 7th October 2005 08:19 PM
Copyright 1999-2017 diyAudio
