Swap Meet Sell your stuff here, who knows, some other fanatic might be interested!
Another CDROM Controller Kit
Old 29th January 2011, 02:51 AM   #161
quadtech is offline quadtech  India
Thanks! Love to see the pics of your completed boards.
Old 18th February 2011, 06:19 PM   #162
Holmes81 is offline Holmes81  United Kingdom
I've just drilled the test PCB and should buzz out the traces to see if any changes need to be made.
If so I should be able to update over the next few days and then post V1 gerber files.
Old 26th February 2011, 07:49 PM   #163
Ok,
I've updated the pcb layout. At the moment it uses a mixture of mt and through hole parts.
I was thinking about changing to total smt when the design has been verified.
I can provide the copper if anyone wants it.
HOWEVER it has not been proved, I have etched the 1st version and conducted a point to point check.
I also have the silk screen as a pdf which shows were all the components go.
Alternatively wait a while and I will etch it again and then hopefully populate and test.
In the current layout the keys are NOT mounted on the board, just a number of 2w connectors. So the users can mount the switches where they want. The IR input is configured in the same manner.
Let me know and I can post the unverified Gerber with a PDF for the silk screen and a list of comps.
Old 1st March 2011, 01:07 PM   #164
cabest is offline cabest
Hi friends,
My project is working but i have to say not without some problems.
And this problems are present using different cd-rom players from different brand.
The less boring is the wrong time counting (track or disc duration / many seconds or minutes). With many players the time is totally wrong and simply unusable (too much cache memory probably).
The most boring is that i have to set the power off after i eject the cd to read another one. Otherwise both project and cd-player are blocked (not responding).
I'll take a look one of these days to try to find an explanation but won't spend lot of time. If i found no solution with the materials by my hands, i will simply put it in a locker. Shame, the sound is really, really great...
Read you soon
Old 21st April 2011, 06:29 PM   #165
Aries1470 is offline Aries1470  Australia
Hi Cabest,
Do you have any update for us?
As for the timing, I think it was mentioned that it was due to caching. It will most likely be unusable for most drives since they all have different amounts of cache, unless someone wants to read the atapi specs and change the program - of which I would not be capable of doing that ;-)
I have not yet begun this project, but I would be interested in one like this. Many other projects omit showing the time, so I guess if someone can write instructions on how the timing / reporting works, maybe it can be configured on a "as needed" basis dependant on cache size i guess. just a thought.
But anyway... back on topic, any updates?
@ Holmes, any luck of getting Eagle done...
Old 1st May 2011, 05:23 AM   #166
I moved away from Eagel to try DesignSpark.
I have reveised the pcb and need to verify the layout then etch and test.
At present there are two type of pcb, both have through hold ICs however one is mainly through hole componenets the other is mainly surface mount components.
I will verify the pcbs at some point, however time is at a premium at the moment so I can't put a date on it.
Old 4th February 2012, 10:48 AM   #167
cutom is offline cutom  Viet Nam
Good topic!
Thank you very much!
Old 27th December 2013, 07:51 PM   #168
Neel007 is offline Neel007  Netherlands
Default Any news on this?
Gents,
I am new here and very interested in this project, something I would like to build myself.
Can someone help me to:
- Schematics
- Hex files and sourcecode
- PCB design
I have found Mr. Pradits schematics and firmware, Cabest's PCB design, should I be able to build it using these?
Thanks everyone for the time and effort everybody invested in this project, I am deeply grateful!
Best,
Neel
Old 28th December 2013, 12:22 AM   #169
woodturner-fran is offline woodturner-fran  Ireland
Not exactly what you want, but I have one of these - not sure if it came from here or ebay. The board is labelled "ysaudio cdrom controller kit". It has a standard 16/2 display, controller keypad, IDE cable to the CDrom.
I'd be happy to let it go to a new home for small money.
Fran
Old 28th December 2013, 12:34 AM   #170
Actually I found the original thread I bought it from:
http://www.diyaudio.com/forums/swap-...5&pagenumber=1
And I have a pdf of the manual.
Fran
Another CDROM Controller KitHide this!Advertise here!
Samsung 1602VFD For CDROM Controller & Remote Volume Controller slowgay Swap Meet 2 22nd November 2008 02:44 PM
CDROM controller muka Swap Meet 17 11th January 2006 08:12 PM
Help with Multi-cdrom controller lapda Digital Source 4 8th February 2004 12:49 AM
they have a 51-based cdrom controller now EJ Digital Source 3 13th July 2002 12:42 PM
