Another CDROM Controller Kit - Page 7 - diyAudio
Go Back   Home > Forums > Commercial Sector > Swap Meet
Swap Meet Sell your stuff here, who knows, some other fanatic might be interested!
Old 10th August 2006, 03:06 PM   #61
pradit, do you still have boards?how much fot a full assembled set(board, remote,programmed pic) without lcd?
Old 10th August 2006, 03:26 PM   #62
ups!sorry...i hanen't seen the look change in the lcd...
do you accept paypal, right?
Old 11th August 2006, 01:49 AM   #63
Yes, right now Paypal only.
Old 6th September 2006, 12:01 AM   #64
khr is offline khr  Russian Federation
Originally posted by cowanrg
ok. i knew about the DAC thing.
i was just wondering how you got from a 2-pin to a coax...
can you just take the two pins and connect them to a RCA jack, then to a dac huh? if so, i think i might go for this project, it sounds good!
pradit please answer
Old 6th September 2006, 02:21 AM   #65
Looking at Post #23 Picture of back side of CDROM.
Audio out can connect to power amp direct sound OK.
Digital out need to connet to External DAC , Which you can get better sound up to your DAC.
Pradit
Old 12th September 2006, 05:09 AM   #66
buts101 is offline buts101  Nepal
Default cdrom controller
hello guys
i need full source code to retriving data from data cd with help of 8051 microcontroller.
thank you
Old 16th September 2006, 07:38 AM   #67
Default buttons
hi pradit_p,
I am going to place a player based on your kit in a box (maybe computer case or similar). I see a problem that control buttons resides on the board and there is no way to attach the board to the flat surface because some pieces are higher than buttons. What can you suggest regarding the buttons, is it possible to detach them off the board or anything else? Thanx.
Old 19th September 2006, 07:42 PM   #68
Send a message via MSN to -_nando-_ Send a message via Skype™ to -_nando-_
Originally posted by pradit_p
Hello Davesaudio
My basic is industrial engineer so I don't know much about computer language what is HLL, ICSP ? If I know what you mean I can explain more.
But I can told you that I use assembly for my PIC16F877A.
For below is my MUCOP Schametic modified to suitable my testboard.
In this schematic, the PIC pin 6 is connected through a 10k resistor to +Vcc instead +5V. Is it a draw error ? Should I connect it to +5V or +12V?
Thanks !
Old 19th September 2006, 10:43 PM   #69
I posted the same question in other topic and I received the answer that it must be connected to +5v, as I did.
I just imported the HEX and programmed, but it isn't working properly.
It just work with one of a few drivers that I have, and the current track time is slower that the our real time, so when music is finishied, the current time don't match with the whole track time.
What the hell is happenning??
Thanks pradit !
Old 7th November 2006, 08:54 AM   #70
Banned
Send a message via MSN to audiodesign Send a message via Skype™ to audiodesign
CDROM Controller webpage
http://www.audiodesignguide.com/sakdaweb
Samsung 1602VFD For CDROM Controller & Remote Volume Controller slowgay Swap Meet 2 22nd November 2008 03:44 PM
CDROM controller muka Swap Meet 17 11th January 2006 09:12 PM
Help with Multi-cdrom controller lapda Digital Source 4 8th February 2004 01:49 AM
they have a 51-based cdrom controller now EJ Digital Source 3 13th July 2002 01:42 PM
Copyright 1999-2017 diyAudio
