FS: Pascal X-PRO3 Amplifier Modules - diyAudio
Go Back   Home > Forums > Commercial Sector > Swap Meet
Swap Meet Sell your stuff here, who knows, some other fanatic might be interested!
Old 16th February 2017, 05:22 PM   #1
Default FS: Pascal X-PRO3 Amplifier Modules
For Sale : A pair of Pascal X-PRO3 3 Channel Amplifier Kits. 3 channels: 1 x 2000W, 2 x 700W.
This includes the amplifier modules and the pro evaluation input board, cables & documentation.
All brand new and have not been used. The actual modules are still factory sealed. The input board is a customized for a pro level input of 7V. Looking for $1350 for the pair. Payment through PayPal. I will ship for free in the USA.
This is the original version of the X-PRO3 Modules, the newest ones are slightly different. See attached images.
PM if you are interested.
___________________________
Power Ratings (RMS @ 1% THD)
Impedance: 4Ω
Channel 1: 2000 W
Channel 2: 700 W
Channel 3: 700 W
Impedance: 8Ω
Channel 1: 1500 W
Channel 2: 400 W
Channel 3: 400 W
Output Circuitry: 3rd Gen Class D - full bandwith PWM modulator with ultra low distortion
Output Voltage: Channel 1 on X-PRO series: 160 Vp / 320 Vpp unloaded All other channels: 80 Vp / 160 Vpp unloaded
Amplifier Gain: Channel 1 on X-PRO series: 32 dB All other channels: 26 dB
Signal To Noise-Ratio: > 120 dB (A-weighted, 20 Hz - 20 kHz, 8 Ω load)
THD+N (typical): < 0,05 % (20 Hz - 20 kHz, 8 Ω load, 1 dB below rated power)
Frequency Response: 20 Hz - 20 kHz (+0/-0.25 dB (8 Ω load, 3 dB below rated power)
Damping Factor: > 1000 (8 Ω load, 1 kHz and below)
Protection Circuits: Input limiter, short circuit protection, DC protection of output, under & over voltage protection, intelligent mains fuse protection, power stage overload protection, temperature protection of transformers and heat-sinks
Readouts for DSP/Network: Protect/Disable (mute), Heatsink temperature, Clip (for each channel), Output voltage (for each channel), Output current (for each channel), SMPS Limit (power supply limiter)
Power Supply: regulated switch mode power supply
Operation Voltage: Universal Mains, 85-268V (dual voltage auto selection)
Old 19th February 2017, 11:27 PM   #2
These are still available.
Old 27th February 2017, 02:20 AM   #3
Bump
Old 4th March 2017, 12:32 PM   #4
Bump
Old 12th March 2017, 08:37 PM   #5
Will you ship to Europe, too?
Greetings
Felix Striebeck, germany
Old 21st March 2017, 02:20 AM   #6
These are still available. Thanks
FS: N 2 First One v.1.2 amplifier modules touchdown Swap Meet 3 24th August 2015 07:11 AM
Pascal Amplifier calss D modules Audio Elite Class D 5 24th November 2014 04:57 PM
How to get Anaview or Pascal amp modules as a DIY'er Viridian Class D 6 4th November 2014 10:16 AM
FS: 2 VSSA amplifier modules supernet Swap Meet 2 24th July 2014 08:11 AM
FS: A few class D amplifier modules RHosch Swap Meet 8 13th October 2005 06:20 AM
Copyright 1999-2017 diyAudio
