For sale...two identical amps.
Each is comprised of:
These are built onto a base steel plate of approx 12" x 12" with a MDF "chassis". There is no top plate.
Power input is via PowerCon.
There is a single XLR input (wired to both UcD modules). If you wanted to you could modify the amp input wiring to make it stereo (it's currently wired as mono, with two channels of output).
Each UcD module has it's own Neutrik NL2 SpeakOn output.
I've checked that the amps power on, but don't have cabling to check beyond that. I've no reason to doubt there would be any issues. They are around 9 years old, but were used regularly until 5 years ago, then have been in storage. If you have any issues with them you can return and I will refund you.
No idea what they are worth, make me a reasonable offer. Mostly I'll be happy if they find a good home and I clear out some space!
- 2 x Hypex UcD180 Rev2 Class-D amp modules
- BHC Aerovox 10,000uF capacitors
- ST BYW99 high efficiency fast recovery rectifier boards
- AnTEK 400vA torodial transformer (dual 120V primaries)
- softstart modules (will include 120V and 240V, 120V current installed)
Still Available?
