Swap Meet Sell your stuff here, who knows, some other fanatic might be interested!
50% off full range speakers
Old 1st January 2016, 08:34 PM   #1
dave 111 is offline dave 111  United States
Default 50% off full range speakers
I've finally selected a full range driver that suits my fancy (the 4fe35) and getting rid of the rest. Their only real use was in comparison testing. So I'd like to get 50% and maybe $5 for shipping.
CHN-70 $27.00 ******SOLD*******
Faital Pro 3fe25 8 ohm $19.00 at Parts Express (If you want the Hilding Horn enclosure they are in that's fine, but the price is going to be at least double as I'm sure they are going to cost quite a bit to ship. **********Sold************
Dayton ND91-8ohm $29.00 at Parts Express. Boxes included. (there is a rather hideous, solder booger on one terminal but that is only because I didn't have a hot enough solderer. It will melt off I'm sure. I was in a hurry and just testing. **********Sold****************
MCM 55-2421 8" subs 4ohm (our rugrat flattened the dustcap on one because it was at her level but it sounds fine) $29.00 at MCM
Old 1st January 2016, 11:01 PM   #2
jameshillj is offline jameshillj  Australia
Dave,
If your vacuum cleaner has a variable vent that allows you to reduce the amount of 'suck' on the end, you can carefully 'pull' that dinted cap out - alternatively, you can carefully hook one of those thin 'tooth probes' thru the dented cap material itself and quietly pull the cap foreward concentrating one part of the dent at a time - this is how the 'pro's' do it - the remaining small hole won't effect the performance at all but if unsure, a small drop of superglue will seal the hole
Old 2nd January 2016, 09:24 PM   #3
thanks, maybe give it a try
Old 3rd January 2016, 02:11 AM   #4
e_fortier is offline e_fortier  Canada
e_fortier's Avatar
Before the 'suck' with the vacuum cleaner, I find that a small dab of water on the dustcap (if cardboard) makes it easier.
Workd great, your dustcap will look like a new one.
BR,
Eric
50% off full range speakersHide this!Advertise here!
Best full range driver between 50-10.000Hz for a 3way system SpirosZ Full Range 71 10th February 2013 03:26 AM
FS: Pair of Radio Shack NOS 40-1354a 5.25" Full Range Speakers - $50 greenmark59 Swap Meet 3 11th January 2011 01:23 AM
Frequency range of the human voice & full range center channel speakers jwmbro Multi-Way 31 20th January 2008 03:07 PM
PEAK FULL RANGE 12TX-50 DRIVERS - Are they worth anything? ozynigma Full Range 0 27th April 2004 07:47 AM
Copyright ©1999-2017 diyAudio
