Logitech Squeezebox SB3 w/Bolder modifications
Included are:
SB3 w/Bolder Digital Enthusiast mod* (please note that analog outputs are fully functional).
SB3 remote
Standard stock SB3 power supply
DUET remote w/charger (so you can see what is playing on a color screen)
Shipping included in Continental U.S.
All original boxes and packaging for SB3
PM for pics. The SB3 and remote are nearly mint, Audiogon 9/10. The Duet remote has some scratches on back, Audiogon 7/10
$OLD. :D
Best,
Anand.
*Digital enthusiast mod is as follows:
"The Digital Only modification is the first level of internal upgrades in the Bolder Cable Company lineup. A Squeezebox with this modification package is intended for use with an external DAC, or in a home theater system where a digital to analog converter is housed in another component. Every Bolder modification package starts with an upgrade to the internal power supply stage of the Squeezebox. All of the power supply capacitors are replaced with a combination of Panasonic FC or Blackgate NC capacitors. Since the internal power supply distributes the current to all the circuit stages in the SB3, these upgrades improve both the digital and analog stages of the Squeezebox. The second half of the digital modification addresses the architecture of the digital output circuit. In the stock SB3, the output of the digital buffer passes through a circuit containing various parts, which includes several inductors and complicated board traces. Wayne has bypassed this portion of the Squeezebox, and installed a proprietary 75-ohm wire, and a 75-ohm WBT NextGen RCA output connector. Now the SB3 has a true 75-ohm output level, which the optimal configuration to interface with a separate digital to analog converter."
