Have some surplus Cobalt Amorphous Toroid Cores - good for Transformers, Inductors \ Chokes,
MSF-20A-T 22.5mm 120μ:
*ruler is in cm
Price is 5$\ea
Registered trackable airmail shipping worldwide - 10$
Paypal is accepted
Manufactureres info:
Cobalt Amorphous Core Toroid MSF-20A-T in hard plastic protective container of glass-polyamide and mechanically fixed with silicone sealant.
MSF series toroidal magnetic cores are made of thin (25 microns) Co-based amorphous ribbon with flat hysteresis loop have high permeability and very low losses.
The container has rounded edges and is designed for direct winding of a thick wire. The container provides reliable mechanical protection and preservation of amorphous material's properties. All materials comply with UL94V-1 / 0.
120μ
Dimensions: 22.5mm-10.4-10.1
High tech modern production, perfect for Audio signal transformers as well as critical applications of Common Mode Chokes
KEY FEATURES OF THE AMORPHOUS MATERIAL:
Induction amplitude, Bm (25°C) 0.59 T
Induction amplitude, Bm (90°C) 0.50 T
Curie temperature, Tc 220°C
Operating temperature range -60°C ... 100°C
Magnetostriction less than 0.1´10^-6
Typical permeability (10 kHz) - 120 000
Typical permeability (100 kHz) - 35 000
ADVANTAGES:
High permeability
Decrease in choke size
Decrease in the amount of winding turns
Low active resistivity
Low core loss
Low wire loss
High impedance in a wide frequency range
Comply with IEC 950, EN 60950, BS 601
Low profile
Full Manufacturers info:
Amorphous Common Mode Choke Cores
*ruler is in cm
Price is 5$\ea
Paypal is accepted
120μ
ADVANTAGES:
High permeability
Low core loss
Low wire loss
Low profile
