I'm selling a complete set of electronics to build 2 UcD400HG HxR Monoblock amplifiers. These came out of new amplifiers with no hours. I'm reusing the chassis and upgrading some of the internal parts.
You will get the following:
2 Hypex UcD 400 HG Amplifier Modules with HxR voltage regulator upgrades installed.
2 Custom machined aluminum heat sinks milled from 6061 aluminum
2 Hypex HG power supplies (Each capable of driving two amps)
2 Hypex custom wound 500VA transformers
2 Hypex Softstart modules
2 Neutrick XLR connectors with input cables soldered on.
4 Insulated binding posts
2 Hard Power Switches
2 IEC power input connectors
2 Tamper resistant chromed momentary buttons
Other custom wire and cable
28 M3 x 10mm standoffs
2 custom turned lag bolts to hold transformers with nuts
The wire lengths are arranged so that they can be installed in symmetric mono chassis. With the exception of input cables the other wire and connectors should give plenty of length without having to rewire. That being said it would be relatively simple to change cable lengths by buying some new wire and crimp pins. If you buy any other parts including from Hypex directly you will have to create all this wire anyway.
Asking - $775.00
Asking - $775.00
