Music Angel Yayi USB Tube amp - 6N3 to 6P1 Push Pull
For sale: Music Angel Yayi USB Tube amp. Works great. $200 + ship.
Ebay has these new for $255 + $96 shipping from China.
Multiple inputs, you can connect a CD player and plays your favorite CDs, or simply read the music files directly from your USB storage device or SD cards (MP3/WAV formats). Built-in tuner and 6 EQs. Remote included, but I never used it. The remote does not have volume control, just presets for tuner and EQ. The remote is a bit of a waste is you ask me...
I used the amp thru CD Input and sounded very good. There is a small dent on back transformer cover, otherwise clean.
Item Specifics from Music Angel Type : Integrated Amplifier
Input Power : 110V
Output Power : 30 watts
Output Tube : 6P1 x 4
Frequency : 5Hz-70KHz
Driver Tube : 6N3
Distortion : Less than 1% at full power
Input Consumption : <80w
Signal/Noise Ratio : 90d
Ohms : 8 ohms
Input Jack : 2 groups (CD Input,AUX Input = USD & SD Card)
Size Dimension : Width 260mm x Height 140mm x Depth 210mm
Colour : Black Body Weight : 8 kg
Pick up in west sub of Chicago, or can ship if buyer pays. Will consider equitable trades...
