Swap Meet Sell your stuff here, who knows, some other fanatic might be interested!
Tripp Lite - Isolator IS250HG Isolation Transformer
Old 16th March 2015, 02:59 AM   #1
moggi1964 is offline moggi1964  England
moggi1964's Avatar
Default Tripp Lite - Isolator IS250HG Isolation Transformer
ust wanted to highlight this is the Hospital Grade unit not the standard one. (Google: TrippLite IS25HG not IS250)
Used for about 10 hours to test it then I packed it up.
Was planning to use it as part of my TubelabSE 300b build as I expected I would get hum from my mains but I don't! Click the image to open in full size.
Asking price is $125 shipped in CONUS. REDUCED TO $105 shipped in CONUS
Imgur
Imgur
Imgur
Imgur
Here is some info from the manufacturer:
Isolator Series UL60601-1 Listed Medical Grade Isolation Transformers offer line isolation, continuous noise filtering and enhanced common mode surge suppression.
An internal low-impedance isolation transformer component offers 100% isolation from the input AC line. Full UL60601-1 medical-grade listing with hospital-grade plug and outlet receptacles makes Isolator medical-grade transformers ideal for protection of sensitive electronic equipment in patient-care areas.
Faraday shield reduces the cumulative leakage current of the Isolator and connected equipment to levels less than 100 microamps. Secondary neutral-to-ground bonding virtually eliminates common mode noise, providing an isolated neutral-ground reference for sensitive equipment, and an inexpensive alternative to dedicated circuits and site electrical upgrades. Removes EMI/RFI noise, utility switching transients and harmonics generated by other on-site loads and utility or lightning related surge conditions. Additional surge suppression components placed at the line input and output combined with full line isolation offer continuous filtering of a full range of power line noise in all modes.
Active transformer filtering provides continuous common-mode noise rejection with no wearable parts. Unique ability to reduce surges in the worst of power environments to harmless levels. Reduces 6000V IEEE587 Cat A&B ring wave and combination wave test surges to only 0.5V common mode.
Model IS250HG includes 2 NEMA5-15R hospital-grade output receptacles, a 6-ft. power cord, hospital-grade input plug, circuit breaker overload protection, and lighted power switch. Rugged all-metal unit housing; ships ready for placement in any industrial, medical, office or network environment. PLUG/OUTLETS: Input - NEMA 5-15P Hospital Grade; Output - 2 NEMA 5-15R Hospital Grade ELECTRICAL: 120V AC, 60Hz, 2.1A (Requires NEMA 5-15R wall receptacle) _
TEAC RH 500 Amplifier Vista Phono1+ w/ TEAC TN-400. Loth-X Ion 1 BS & Emotiva XDA2. WIP: Tubelab SE 300b
Old 7th April 2015, 11:42 PM   #2
moggi1964's Avatar
Sold
Tripp Lite - Isolator IS250HG Isolation TransformerHide this!Advertise here!
Newbie Question - Power Transformer vs Isolation Transformer SparkyPete Tubes / Valves 10 2nd November 2012 06:13 PM
Tripp Lite Isolation Transformers Skitch72 Swap Meet 4 14th April 2010 05:01 PM
Using isolation transformer as a PSU transformer??? Yaho Tubes / Valves 10 27th February 2008 04:16 AM
(2x) Tripp-Lite UPS SNMP solo modules bluesmoke Swap Meet 1 4th May 2007 02:13 PM
Isolation Transformer HarryHaller Solid State 9 5th August 2002 12:30 PM
Copyright ©1999-2017 diyAudio
