Hammond 125ESE 15 Watt Single Ended Output Transformers - diyAudio
Go Back   Home > Forums > Commercial Sector > Swap Meet
Swap Meet Sell your stuff here, who knows, some other fanatic might be interested!
Old 6th February 2015, 05:45 AM   #1
Default Hammond 125ESE 15 Watt Single Ended Output Transformers
For sale is a pair of Hammond 125ESE Single Ended Output Transformers. These have an air gap as expected with single ended designs and are rated at 80ma for 15 watt power delivery. These would work up to a 300B or KT88/6550 tube if so desired. Of course one could go smaller, I was planning on using them for a 2A3 amplifier.
I bought one of these units a few years ago to use on my bench to test a design. I actually had it on a chassis for a little bit and cut the leads down. The shortest lead is 3" the others are 4" or longer. I picked up another one new expecting to finish the build, but ended up going another direction and these have sat around in my garage for the last 4-5 years (and moved across several states once). So they have some wear on the paint as can be seen on the images but will work as good as new. Frankly, they're not terribly pretty stock and I was planning on potting them or using them under the chassis.
I figure if I haven't used them by now it's time to let someone else enjoy them.
These transformers are immensely flexible with the option to use them with a primary of: 10,000, 5,000 or 2,500 ohms and secondaries of 4,8,16 or 32 ohms. This makes them perfect for experimenting and people who have actually built amps with them are usually quite pleased with their sound.
Shipping will be a via a USPS flat rate box and is only available to the Continental United States (Sorry to those friends overseas and up North and down South. Shipping will be set at $13.00. Paypal accepted. I'm asking $80.00 for the pair.
I may consider trades for full range 6.5" drivers or a Non-Oversampling DAC with SPDIF/TOSLINK and USB input.
Thanks for looking at my ad!
Last edited by Dilmonkey; 6th February 2015 at 05:49 AM. Reason: forgot the price again
Old 6th February 2015, 05:58 AM   #2
hatrack71's Avatar
PM sent with intention.
WTB: Single Ended Output Transformers Zedguy Swap Meet 2 2nd August 2009 03:05 AM
Pair Hammond 1628SEA single ended transformers for $175 njradiodoctor Swap Meet 0 21st May 2009 02:32 PM
Pair Hammond 1628SEA single ended transformers for $199 njradiodoctor Swap Meet 0 22nd March 2009 01:06 AM
Black Art Single Ended Output Transformers DVDHack Tubes / Valves 2 11th January 2004 05:02 AM
FS: Pair Hammond 125ESE single ended output transformers Saurav Swap Meet 3 28th August 2003 07:44 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2015 DragonByte Technologies Ltd.
Copyright 1999-2015 diyAudio
