Selling 13 long fin Heat sinks w/mounting plate
I have for sale 13 heat sinks w/ mounting plate.
8 1/4 long x 4 1/2 x 2 3/4 high (fins). Base is 1/4 thick with tapped mounting holes. mounting plate is 4 5/8 x 2 5/8 x 1/2.
Weight is 1108g.
$20 each. Shipping to Canada and USA. Outside of North America might be too much.
Free shipping in Canada and 1/2 shipping in US when you buy 2 or more.
The mounting plate has 2 drilled holes that are matched on the heat sink. You can mount your transistors to the plate and then to the heat sink. Best to use these sinks with forced air cooling, Pc fans 80mm or larger for great cooling and no noise.
