I'm selling the following:
2-Memphis MC-500d - $140 each
2-Memphis 16-MC150 - $140 each
1-Memphis 15-MCSQ6.5 - $100
1-Stinger Digital 3 Farad Car Audio Capacitor, model # SHD3M - $150
I would like to sell the amps all together otherwise I'll keep them. Prices are OBO and are all in great working condition. They have minor scratches, but have been maintained in great shape.
Contact Jason at: jwood1627 at gmail
Descriptions:
Memphis MC-500d
Power Specifications - Full Range Channels
RMS Power @ 4 ohms
250 watts x 1 channels
RMS Power @ 2 ohms
500 watts x 1 channels
RMS Power @ 1 ohm
Not Stable
Bridged RMS Power
Not Bridgeable
Peak Power Output
1000 watts
Amplifier Specifications
Number of Channels
1 - Mono
Total RMS Power Output
500 watts
Minimum Impedance Unbridged
2 ohms
Minimum Impedance Bridged
Not Bridgeable
THD at Rated RMS Power
0.5%
Speaker Level Inputs
No
Preamp Outputs
1 pair
Signal-to-Noise Ratio
95 dB
Bass Boost
0 - 18 dB
Fuse Rating
25A x 2
Memphis 16-MC150
RMS Power @ 4 ohms
75 watts x 2 channels
RMS Power @ 2 ohms
115 watts x 2 channels
RMS Power @ 1 ohm
Not Stable
Bridged RMS Power
230 watts x 1 channels
Peak Power Output
150 watts x 2 channels
Amplifier Class
AB
Number of Channels
2
Total Peak Power Output
300 watts
230 watts
Maximum Input Gauge Size
8 AWG
2 ohms
4 ohms
0.03%
No
Preamp Outputs
1 pair
Built-in Crossover
Low-pass (LP)
High-pass (HP)
Full (AP)
High-Pass Crossover Frequency
40 - 6000 Hz
Low-Pass Crossover Frequency
40 - 6000 Hz
90 dB
Bass/Gain Remote
No
Fan Cooled
No
Fuse Rating
15A x 2
Great cap and in good shape, it has plenty of connection points for multiple uses with a voltage adjust, accepts up to 0 gauge wire. Anodized with chrome accents and a low-voltage alarm cut-off to keep your cars battery from dying if the voltage drops below the safe threshold. 20-volt / 24-volt surge foil construction, integrated power distribution, integrated digital voltmeter and heavy duty extruded aluminum housings. Digital monitor, 3 farad, 10 x 6.5 x 3.25 . ESR 1.2 mOhm, tolerance 10%
Brand new sells for over $300
Memphis 15-MCSQ6.5
• Injection molded composite basket
• Glass fiber cone
• Rubber surround
• Kapton voice coil
• Low-loss 12dB/octave design
• 6.5" Diameter 50watts RMS / 100watts MAX
• 4 ohm Impedence
• 40hz-20khz Freq. Response
• 88db Sensitivity
• 2.6" Mounting Depth
Descriptions:
Memphis MC-500d
RMS Power @ 4 ohms
RMS Power @ 2 ohms
RMS Power @ 1 ohm
Not Stable
Bridged RMS Power
Not Bridgeable
Peak Power Output
1000 watts
Number of Channels
1 - Mono
500 watts
2 ohms
Not Bridgeable
0.5%
No
Preamp Outputs
1 pair
95 dB
Bass Boost
0 - 18 dB
Fuse Rating
25A x 2
Memphis 16-MC150
RMS Power @ 4 ohms
RMS Power @ 2 ohms
RMS Power @ 1 ohm
Not Stable
Bridged RMS Power
Peak Power Output
Amplifier Class
AB
Number of Channels
2
300 watts
230 watts
8 AWG
2 ohms
4 ohms
0.03%
No
Preamp Outputs
1 pair
Built-in Crossover
Low-pass (LP)
High-pass (HP)
Full (AP)
40 - 6000 Hz
40 - 6000 Hz
90 dB
Bass/Gain Remote
No
Fan Cooled
No
Fuse Rating
15A x 2
Memphis 15-MCSQ6.5
• Glass fiber cone
• Rubber surround
• Kapton voice coil
• 4 ohm Impedence
• 88db Sensitivity
