Tempest-X?
Miguel,
I have an Exodus Tempest-X which is still a very capable subwoofer driver (27mm x-max with the XBL^2 motor). Shipping won't be too cheap, but we might be able to work something out - let me know if you're interested at all. It too is a dual-8 ohm configuration.
Best,
Tal
T/S parameters for the Tempest-X:
Fs: 18.5 Hz
Le: 0.90mH
Re: 3.65 Ohms (Voice Coils wired in parallel)
Qms: 3.4
Qes: .60
Qts: 0.51
Mms: 200g
Cms: 0.37 mm/N
Vas: 324L
Sd: 791 cm^2
Vd: 4.27L
BL: 11.86
X-max: 27mm
Pmax: 600W
SPL: 87.2 db/1W/1M
Miguel,
Best,
Tal
Fs: 18.5 Hz
Le: 0.90mH
Qms: 3.4
Qes: .60
Qts: 0.51
Mms: 200g
Cms: 0.37 mm/N
Vas: 324L
Sd: 791 cm^2
Vd: 4.27L
BL: 11.86
X-max: 27mm
Pmax: 600W
SPL: 87.2 db/1W/1M
