| Swap Meet Sell your stuff here, who knows, some other fanatic might be interested! |
For Sale:
I have about 45 of these Grayhill 6-position horizontal PCB mount rotary switches, part # 71ADF30-02-2-AJN. I bought them months ago for use in a project that went a different direction. Newark sells these switches for $26.73 each here: http://www.newark.com/NewarkWebComme...jsp?id=57F3767 Specs can be found at that link. Welborne Labs also offers these switches as a high quality source selector. I would like only $5 per switch, or ten for $40, or buy them all for $125. This is a fantastic deal for anyone looking for a rotary switch to use on their boards. Please contact justin at headamp.com if interested. ![]()
#2 |
#3 |
I've emailed you through the email button on the page. Should I email somewhere else, or will that be sufficient?
#4 |
Can you send me the specs of this switch. I need a few and want to know if it's a silver plated or gold plated of something else. Please e-mail me direct. Best regards, Audiofanatic my_name@planet.nl
Be nice to animals. |
#5 |
#6 |
antness: i've emailed you and justin, no reply on either .. i'm interested in 2 of these
edit: i've just gotten a response from justin |
#7 |
I just got your email and sent you a reply
#8 |
One additional question (i've sent payment btw). It seems you can use one of these switches to switch both signal AND ground for two channels, is that right? Or is the switch in picture a 12 position one?
#9 |
I'm really not sure, I havent used these switches.
The part # is 71ADF30-02-2-AJN The datasheet is here: http://embrace.grayhill.com/embrace/...DF/J-31-44.pdf This should answer all of your questions |
#10 | |
Thank you, it did actually answer my question (looking over one of the diagrams). The answer, for those who may care, is that yes, you can use it to switch both the ground and the inputs at the same time, thus avoiding the need to combine the input grounds. also, some other information that may be of interest to anyone interested in these (all these gathered from the model # that was stated in the first post btw) they're non shorting, have adjustable stop switches (not sure if any additional hardware is required), and have a 30 degree angle of throw .. |
| 25-position switched attenuator using a pair of 5-position switches? | ray_moth | Tubes / Valves | 1 | 4th May 2008 08:02 AM |
| Optical Rotary Encoder Volume Control unit using the Grayhill 62P | DJ Exprice | Everything Else | 17 | 1st January 2008 08:50 PM |
| Grayhill 7 pole 20 position rotary switch | Bill Fitzpatrick | Swap Meet | 25 | 5th May 2004 04:45 AM |
| A simple way to create dual(or more!) rotary switches out of single rotary switches | stappvargen | Pass Labs | 14 | 16th April 2004 11:33 PM |
| Grayhill 7pole 20 position rotary | Bill Fitzpatrick | Swap Meet | 15 | 19th November 2002 01:15 PM |
| Page generated in 0.09370 seconds (81.98% PHP - 18.02% MySQL) with 10 queries |
