All I know is that 627/637 are good in the signal path and that they are high bandwidth/high speed/expensive so not really the best for servos (only low offset is the right parameter) where you need slow low noise opamps with low offset numbers. In the past the LF411 was one of the most suitable with good results for that reasons. I am too lazy now to compare specs. BTW they only cost 1 Euro...
Yes you can buy your groceries and use the Ferrari but a shopping cart might be more practical...
