Swap Meet Sell your stuff here, who knows, some other fanatic might be interested!
JL Audio
JL Audio
Old 17th January 2014, 03:50 PM   #1
Levictus is offline Levictus
Default JL Audio
Hi guys
I'm new to the forum. Admittedly, I came here as directed by my local audio guy to sell a brand new in box JL Audio 500/5 amp as an alternative to Craig's List or a eBay, but I don't see a classified section anywhere. Am I missing something?
I apologize in advance if this is in the wrong place...
Old 17th January 2014, 03:55 PM   #2
On Hiatus
SY's Avatar
JL Audio
Moved to the right place by your friendly neighborhood moderation staff.
"You tell me whar a man gits his corn pone, en I'll tell you what his 'pinions is."
Old 17th January 2014, 04:04 PM   #3
Thanks SY...
Old 17th January 2014, 04:10 PM   #4
I will post pictures later today as I also have the remote bass knob new in box that I want to offer along with it. As I said, it is brand new in box. It had been opened upon original shipment for inspection and measuring. My project fell by the wayside as I got married then had twin boys, and has been under my bed for a number if years. Again, never been mounted, never been connected to anything.
Old 17th January 2014, 04:13 PM   #5
architect7 is offline architect7  United States
architect7's Avatar
You might have better luck on caraudio.com and/or diymobileaudio.com, lots of JL car audio fans there
Old 17th January 2014, 04:15 PM   #6
Thanks for the tip architect7, I will check them out
Old 17th January 2014, 06:46 PM   #7
JL Audio 500/5 5 Channel Car Audio Amplifier
Specifications:
Front Channels: 100W RMS x 2 @ 1.5 ohm-4 ohm (11V-14.5V)
Rear Channels: 25W RMS x 2 @ 1.5 ohm-4 ohm (11V-14.5V)
Subwoofer Channel: 250W RMS @ 1.5 ohm-4 ohm (11V-14.5V)
THD at Rated Power: <0.03% @ 4 ohm (F&R), <0.05% @ 4 ohm (Sub)
S/N Ratio* (F&R): >108.5 dB below rated power
S/N Ratio* (Sub): >95 dB below rated power
Frequency Response (front and rear): 5 Hz-30 KHz (+0, -1dB)
Frequency Response (sub channel): 5 Hz-500 Hz (+0, -1dB)
Damping Factor (front and rear): >200 @ 4 ohm/50 Hz
Damping Factor (sub channel): >500 @ 4 ohm/50 Hz
Input Range: switchable from 200mV-2V RMS to 800mV-8V RMS
Dimensions: 19.7"L x 9.25"W x 2.36"H
Features:
Differential-Balanced Input Topology: (3 pairs of inputs)
Front Crossover: Fully-variable (50 Hz-5 KHz), selectable-slope BP or HP (12 or 24 dB per octave)
Rear Crossover: fully-variable (50 Hz-5 KHz), selectable-slope HP (12 or 24 dB per octave)
Sub Crossover: fully-variable (40-200 Hz), selectable-slope LP (12 or 24 dB per octave)
Preamp Output: 2-channel (full-range or LP)
Bass EQ: Variable boost up to 15dB. Remote bass boost control optional.
Infrasonic Filter: defeatable 24dB/octave at 30 Hz
Left minus Right Ambience Circuit: ambient effect for rear channels
Front and rear speaker output connections: accept up to 8ga. wire
Dual mono subwoofer output connections: accept up to 8ga. wire
+12V and Ground connections: accept up to 4ga. Wire
1-year SonicElectronix.com warranty
Pictures are of actual products (sorry, it seems post is only letting me upload 1 photo, pm me and I can email others). In original box/packaging with manual and Allen key.
This amp sells between 350-400 in good used condition. The only new one I have seen is $525 + shipping. I am also including the RBC-1 remote bass control knob which directly interfaces with the amp. They sell for about $30.
Asking $475 includes standard shipping, PayPal only, to a verified US PayPal address only. Let me know if you have any questions.
Old 17th January 2014, 09:59 PM   #8
Item Pictures:
Old 22nd January 2014, 02:07 PM   #9
Anyone? Reasonable offer? Let me know before I pull it and put it on Craigslist and eBay...
JL AudioHide this!Advertise here!
JL Audio 300/4 Low Audio Output Troubleshooting Tip kds9591 Car Audio 3 25th December 2012 01:09 PM
Jl audio 500/1 powers on with low audio out help needed ivkata Car Audio 29 19th August 2011 12:21 AM
Can I run a 10 inch JL audio and a 12 inch JL audio off same amp ash4kel Car Audio 2 8th April 2011 02:12 AM
JL Audio 10w6v2 or Infinity Kappa 100.3se? Audison SRX4 or Jl 300/4? DcMaN Subwoofers 1 17th September 2010 10:28 AM
