Swap Meet Sell your stuff here, who knows, some other fanatic might be interested!
FS: Threshold SA/3 Stasis Optical Bias Amp
Closed Thread
Old 11th January 2014, 01:08 AM   #1
uberchurl is offline uberchurl  United States
Default FS: Threshold SA/3 Stasis Optical Bias Amp
The legendary Threshold SA/3 Stasis Optical Bias Class 'A' power amp by Nelson Pass. Most Threshold enthusiasts agree that the "SA/" models are the finest example of the Pass-era Threshold amps. It is most definitely "built like a tank"; no scratches or dents, and performs flawlessly. It includes a unique, high quality upgrade consisting of a close-coupled self-contained capacitor bank. Pause the music, drive the amp full bore and you won't hear a single sound...complete silence. Incredible soundstage from this high quality class 'A' power amplifier.
RATED OUTPUT: 50 watts/channel @.05% distortion
BANDWIDTH: -3dB at 7Hz and 100,000 Hz
SLEW RATE: greater than 50 volts per microsecond
INPUT IMPEDANCE: 75,000 ohms
OUTPUT TRANSISTOR COMPLEMENT: 14 transistors/channel
OUTPUT CURRENT CAPACITY: 16 continuous, 80 peak amperes (fuse governed)
POWER SUPPLY: 700 watt toroidal transformer, 60,000 microFarads capacitance
OUTPUT IMPEDANCE: Less than 0.03 Ohm 20Hz - 20,000 Hz
GAIN FACTOR: +26.6 dB
NOISE: No greater than -100dB, unweighted, referenced to rated output (input terminated in 600 ohms)
LOAD RATING: Operation is allowed into any load as permitted by power supply fuses and thermal protection.
WEIGHT: 56 lbs / 25.5 kg
DIMENSIONS: 9.6"H x 19"W x 13.125"D
Includes capacitor box, multi-pin locking cable, ac power cord, and copy of user manual.
Price is $1200 which includes packing/shipping to USA lower 48 states. For other destinations, the shipping weight is approximately 70 lbs; please contact me for a shipping estimate. For local pickup, I am located in the Pasadena/Los Angeles area.
Old 16th June 2014, 03:28 PM   #2
Cal Weldon is offline Cal Weldon  Canada
Speakerholic
Cal Weldon's Avatar
Member has stated the item is sold.
planet10 needs your help:
Let's help Ruth and Dave
Closed Thread
FS: Threshold SA/3 Stasis Optical Bias AmpHide this!Advertise here!
Yet another Threshold STASIS bias thread Redwingnine Pass Labs 11 22nd February 2011 08:33 PM
Threshold Stasis 2 Class A Power Amp - bias setting? speakerfritz Solid State 19 12th February 2011 03:28 AM
Threshold stasis sa-3.9e Williams Audio Solid State 3 23rd November 2010 05:53 PM
Tech help needed Threshold S/300 MkII optical bias georgehifi Solid State 15 17th January 2005 01:30 AM
Threshold Stasis S/300-2 optical a-ab georgehifi Solid State 3 30th September 2003 02:18 PM
