FS: eXD 32bit/384kHz, DSD64, DSD128 USB receiver
Sorry! These are both SOLD!
I have two (2) of these very lightly used eXD USB receivers. They're asynchronous, work with standard USB drivers and frankly - sound fantastic. These eXD boards are the same ones used in the Sonore DAC.
As equipped each sells for $399 new. I'll sell each for $150, plus shipping and any paypal fees.
Cheers!
Hi Do. Since it doesn't require any custom drivers, it should work well with Linux.
The website of the manufacturer has a lot of information about Linux use:
exD
Re: PCM/DSD switching, the OTTO II has worked very well for this. Actually, one of the two eXD cards I have is programmed to output PCM/DSD over the same pinouts, so no switch is needed.
exD
Is it the one that says DSD-ESS on it? what are the dimentions of the board?
Do
Yup, that's it. The board is 100mm x 92mm.
Outch... that's big! I'll check if it can fit in the enclosure. My main use would be with Volumio which uses MPD. I want to be able to play DSD without using the OTTO module since I do not find this an elegant solution but I also want it to be compatible with MPD... I think they may be using DoP but don't know if they do straight DSD out as well since I believe it is what the card requires, correct?
Also, I wend on their site but it is a Blog and you can't find anything in there.
Do
