APS UPC battery backup packs - diyAudio
Go Back   Home > Forums > Commercial Sector > Swap Meet
Swap Meet Sell your stuff here, who knows, some other fanatic might be interested!
Old 21st August 2013, 04:21 PM   #1
JoshK is offline JoshK  Canada
Default APS UPC battery backup packs
2 x APS (can't remember if it is APS or ADS) *UPS battery backup packs. Each one consists of 8 12V/9AH SLA's wired in series/parrallel for 54.4V output. The units have a built in auto charger that charges the batteries when 10% less than full charge and then switch off again.
I used two to run UcD400s off of, but for ease and space, I am running them on AC now. They weight >50lbs each, so local pickup is best. $50/ea
Old 22nd August 2013, 01:21 PM   #2
I don't have a picture handy but these are rackmount size (audio component size) and about 3.5" tall or so. A friend of mine (now past, RIP) was the first to run UCD400 modules off these and took the chargers out and placed on switch, mounted the modules inside the packs and added connectors and binding posts to make them into amp cases. Pretty clever. I have pictures of his project, which show the cases after his mods.
Old 22nd August 2013, 02:07 PM   #3
To further whet the appetite of what can be done with these. Here are parts from my time when I ran UCD 400s off them.
I also have the following:
black par-metal chassis used in a couple of amp projects. Front panel drilled for meters below, but could order new one or make your own. Chassis $40 with the connectors that are currently installed and switch for front panel.
2 each 0-80V DC vintage meters. $40/ea
In regards to the original battery power packs, the supremely heavy part is the batteries. So if I were to ship, i could always remove the batteries and you source your own locally (like from a surplus center). The extremely useful tidbits are the charging circuits and the chassis.
Old 26th August 2013, 05:57 PM   #4
bump
Old 9th September 2013, 06:59 PM   #5
some pictures of my units
as I mentioned above, they can be shipped sans batteries to make the weight more manageable. Also I have UCD400 units I could sell with.
Old 16th September 2013, 01:08 PM   #6
little knudge
Old 22nd January 2014, 04:00 PM   #7
Anyone in Canada want to make some battery powered amps?
Car battery as UPS backup MarianB Power Supplies 22 23rd April 2013 09:59 AM
Where to buy li-ion battery packs in Europe? Hitec Parts 4 9th February 2011 07:08 AM
Home Theater Battery Backup/Power Cond/Surge Protector/ rh1530 Swap Meet 0 4th January 2009 07:40 PM
FS: APC Battery Packs JoshK Swap Meet 3 3rd November 2008 07:59 PM
uPC 1298 palesha Parts 8 25th January 2006 03:22 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2014 DragonByte Technologies Ltd.
Copyright 1999-2014 diyAudio
