Group buy on Sn96.5 Ag3.5 solder... - diyAudio
Go Back   Home > Forums > Commercial Sector > Swap Meet
Swap Meet Sell your stuff here, who knows, some other fanatic might be interested!
Old 12th December 2003, 01:49 PM   #1
Default Group buy on Sn96.5 Ag3.5 solder...
Hey guys,
I'm thinking of buying some silver solder. The problems is that it's a custom order, and very expensive unless I buy quantity. So, if there's enough interest I may order a bunch, and sell the rest. I'd need to sell about 20 rolls.
The mrf would be Kester, the solder mix would be Sn96.5, Ag3.5. Flux core would be #44 Kester, 3.3%. Dia .020 inches.
Approximate cost would be $40 per roll, for a 1 pound roll.
Any interest?
-Dan
-With a bad amp, everything sounds the same. It takes a good amp to tell the difference between true "Artists" and the rest of the "Performers".
Old 12th December 2003, 02:09 PM   #2
bigparsnip's Avatar
Hi, I don't know if this will be of any use to you, but I can get hold of 1/4, 1/2 or 1 pound rols of 4% silver, 0.5% copper and 95.5% Tin for much less than the price you have been quoted there (something in the region of $5, $9 and $17 respectively), so if you look around you may be able to find a standard part would be a lot cheeper, unless you are interested in that specific composition.
Old 12th December 2003, 02:44 PM   #3
I'm looking for the silver for temperature, and strength characteristics (Not sound quality). How good is the alloy for strength? Do you know what the melting point is?
The stuff I'm quoting is about $115 per pound, with a minimum of 5 pounds. Price drops to around $40 per pound at 25 lbs.
-Dan
Old 12th December 2003, 02:48 PM   #4
bigparsnip's Avatar
Hi, I'm not too sure about that at the momnet, but I will see if I can find out some more information for you, or get you a link to the manufacturers web site.
Old 12th December 2003, 03:16 PM   #5
Thanks!
I've seen copper used in alloys, but not very often.
The stuff I'm quoting is a Eutectic blend... ..or close to it.
-Dan
Old 12th December 2003, 03:26 PM   #6
UrSv is offline UrSv  Sweden
UrSv's Avatar
How about Multicore 96S 362 which is Sn 96,3 %, Ag 3,7 %?
UrSv
Those who say it can't be done should not stop those who are doing it.
Best solder to use rtarbell Parts 4 20th November 2005 02:05 AM
what solder should be used ?? kambule Parts 27 8th August 2005 02:16 PM
can I solder on this? Duck-Twacy Multi-Way 9 24th February 2004 01:46 PM
how do you solder? theChris Equipment & Tools 15 2nd January 2003 11:55 AM
Solder again Christer Parts 13 6th December 2002 01:48 PM
Copyright 1999-2017 diyAudio
