FS: Behringer DCX2496 - 2 channels not working - diyAudio
Go Back   Home > Forums > Commercial Sector > Swap Meet
Swap Meet Sell your stuff here, who knows, some other fanatic might be interested!
Old 13th August 2013, 09:00 PM   #1
ua100k is offline ua100k  United States
ua100k's Avatar
Default FS: Behringer DCX2496 - 2 channels not working
All input channels are working, all other functions are working. Only 2 of the 6 output channels are not working. The other 4 are working.
4 output channels have a opa1612 op amp in it. 2 channels are missing the op amps and some of the resistors. You can replace the opamps and resistor to get the channels function however you will have to find out the values of those missing components from the other 4 channels or get a circuit.
The Opa1612 are better op amps than the stock opamps, however it has a bit of noise in channel. One channel has more noise than the others. This could be due to the op amp gone bad in the process or the op amps are not a good match.
I don't have a box. The top screws on the panel to open it up are missing.
$75, OBO. plus shipping.
Audio Purity
Old 13th August 2013, 09:06 PM   #2
Pano is offline Pano  United States
Pano's Avatar
Seems like a good candidate for the passive output modification.
Old 14th August 2013, 06:21 PM   #3
ua100k's Avatar
Default Behringer DCX2496 mods
Actually good for a lot of mods.
1. Transformers for in and out.
2. Change the ribbon cable to hard wire
3. Change the AK DAC to the 192 DAC - still 96k but better specs.
4. Change the input opamps.
5. If you have external buffers, try it directly to the A/D and D/A, removing input, output stages, relays, ribbon cables and connectors. This is only for the very experienced.
6. Change power supply. I would suggest lots of caps on the boards - filter and supply on each opamp, at the opamp location.
Audio Purity
Old 15th August 2013, 01:11 AM   #4
Zero Cool's Avatar
Email sent
It's not about what you can BUY...It's about what you can BUILD!
FS : Behringer DCX2496 korben69 Swap Meet 1 30th August 2012 09:02 AM
FS: Behringer DCX2496 (Boston) sts9fan Swap Meet 2 19th May 2012 02:29 AM
FS: Behringer DCX2496 (NIB) beeah Swap Meet 3 23rd March 2012 02:13 PM
FS Behringer DCX2496 HIPCHECK Swap Meet 1 30th September 2010 05:19 AM
FS: Behringer DCX2496 brand new Vadim Swap Meet 4 23rd March 2004 04:23 AM
Copyright 1999-2017 diyAudio
