Swap Meet Sell your stuff here, who knows, some other fanatic might be interested!
FS: UK, Built Connex TA3020, Hifimediy T1 TK2050 and Rotel RA-930AX
Old 4th August 2013, 08:52 PM   #1
Flibble is offline Flibble  United Kingdom
Flibble's Avatar
Default FS: UK, Built Connex TA3020, Hifimediy T1 TK2050 and Rotel RA-930AX
Having a clear out to free up some space and money:
First is a connexelectronic TA3020 v2 in a Samson 19" rack mount case, transformer is 30v x 2 at 2.5A (while it won't take the board to its limit is far more power than you'd ever need at home), Alpha 50k pot and decent mic cable on input. Top and back piece are acrylic, planned to swap this for ali sheet but never got round to it, will include all the original LEDs and both pots for the case. 60.
Second is a Hifimediy T1 in a modded mini-ITX case, has a totally OTT toroid with 2 12v windings in series for 24v, 2 parallel Jamicon 10000uF smoothing caps. Alpha pot and decent mic cable on input. 60.
Thirdly is a Rotel RA-930AX totally standard and everything working fine, plastic base had cracked so replaced this with a bit of acrylic (which needs replacing with something more substantial). 35.
Postage on each of these will run to about 10 in the UK (tracked and insured), or collection from Lancaster welcome. I'll be away with intermittent internet access till the 13th but will answer any question as soon as I can. Both tripath amps have only had light use and sound great.
Thanks,
Dan.
Old 9th August 2013, 08:02 PM   #2
Flibble's Avatar
Tripath amps reduced to 50 each for quick sale (before they go on ebay....). Postage in the UK only. Cheers, Dan.
Sent from my Galaxy Nexus using Tapatalk 4
FS: UK, Built Connex TA3020, Hifimediy T1 TK2050 and Rotel RA-930AXHide this!Advertise here!
Bypassing tone switch on Rotel RA-931 and RA-930AX lars667 Solid State 6 10th June 2012 03:39 PM
FS: Tripath TK2050-Hifimediy T1 Module Alps force of 1/2 Swap Meet 0 4th May 2011 01:51 AM
FS: TK2050 Hifimediy AMP mravlca Swap Meet 6 28th April 2011 10:19 PM
rotel ra-930ax repare. fozy_50 Solid State 2 17th February 2011 01:23 PM
Rotel RA-930AX One channel out No sound mrfix90 Solid State 6 2nd September 2009 05:58 AM
