Swap Meet Sell your stuff here, who knows, some other fanatic might be interested!
FS: LM49710/LM49600 Amp (The Wire-ish) and +-15v Bipolar supply, 600:600 Transformers
Old 11th July 2013, 07:33 PM   #1
wireswithgain is offline wireswithgain  United States
Default FS: LM49710/LM49600 Amp (The Wire-ish) and +-15v Bipolar supply, 600:600 Transformers
Up for sale is an amplifier that, much like a better version of "The Wire" headphone amp, uses 1 LME49710 TO-99 Metal can per channel for voltage gain, and 2 LME49600s for current gain. Feedback resistor has been left blank so you can choose your own gain (stock value 20k). Dale resistors, WIMA and Nichicon caps. Comes with a +15/-15v hand-built PSU that uses LM7815/LM7915 linear regulators, Nichicon MUSE electrolytics, MKP1841 decouplers, and IXYS diodes.
$100 OBO.
I have a suitable 115v/230v R-core transformer if you need it, $15 extra.
Also are some un-identified 600:600 interstage/output transformers that I bought on here awhile back from another user. I've been using them with a CS4397 and they sound pretty darn good. I upgraded to Jensens.
$40 for both OBO
Shipping and Paypal fees not included.
PM me!
Last edited by wireswithgain; 29th July 2013 at 10:04 AM. Reason: corrected part number
Old 15th July 2013, 02:50 PM   #2
bump
Old 16th July 2013, 05:28 PM   #3
I might sell the headphone amp for a bit cheaper, someone make a reasonable offer. Keep in mind the op-amps alone are worth $40.
Old 17th July 2013, 02:57 AM   #4
Mikett is offline Mikett  Canada
Where can I see the schematic?
Old 17th July 2013, 03:25 AM   #5
Here's the schematic, very simple.
Old 17th July 2013, 02:10 PM   #6
Have you tested the circuit for any oscillation as per layout?
I am concerned about the sharing of the load and whether load resistors have been omitted.
Would you consider without the Power Supply?
Otherwise I am interested.
Old 17th July 2013, 02:51 PM   #7
I haven't hooked it up to a scope, but I didn't have any oscillation problems when I was using this board with the stock gain settings (21) to test it as a headphone amplifier. It sounded very detailed and dynamic and I didn't have any problems with it connected to my Sennheiser HD580s.
I'll sell it without the power supply. I'll PM you.
Old 18th July 2013, 03:02 PM   #8
bump
Old 21st July 2013, 10:31 PM   #9
bump
Old 29th July 2013, 10:04 AM   #10
bump
FS: LM49710/LM49600 Amp (The Wire-ish) and +-15v Bipolar supply, 600:600 TransformersHide this!Advertise here!
Use of Tango NN-600-600 Transformers ? HP8903B Tubes / Valves 12 6th October 2014 08:49 AM
FS: The Wire amplifier with DPS-600 power supply igor0203 Swap Meet 4 13th March 2013 06:15 AM
FS cinemag transformers nickel CMOQ-2H 600:600 Gluca Swap Meet 10 6th March 2013 06:01 PM
FS/Trade Hammond 850G 150/600:150/600 Line Isolation/Hybrid Matching Transformers VictoriaGuy Swap Meet 0 3rd August 2011 09:29 PM
Home Theater Amp $600 ish rang? electricashman Everything Else 9 12th July 2006 07:14 PM
