Here is some info from the TP website and a photo
4-Channel S/PDIF (or AES-EBU) Level Converter Kit
To make it easier to feed multiple consumer level S/PDIF inputs to the Buffalo-III, we have created a 4-Channel Level Converter which mates up perfectly with the Buffalo's input header.
Each input is transformer isolated and fed to a high-speed quad-compatator for TTL-level shifting from consumer-level or AES/EBU signals. Termination resistors are provided for Consumer, AES/EBU and TTL-level inputs. It can be connected directly to the Buffalo (soldered) or via a 20-pin ribbon cable and connectors (included).
http://www.twistedpearaudio.com/images/digital/spdif_4_full.png
