Swap Meet Sell your stuff here, who knows, some other fanatic might be interested!
FS: Tim Rawson F5 clone amp
Old 16th August 2013, 10:05 PM   #11
anubisgrau is offline anubisgrau  Serbia
i bet it sounds good
Old 17th August 2013, 06:52 AM   #12
Rodeodave is online now Rodeodave  Austria
hates ground loops
Rodeodave's Avatar
I'm not good at detecting sarcasm, but this better be.
Gravity - Making the G since 13.7 billion B.C.
Old 28th October 2013, 03:45 PM   #13
jonparkhurst is offline jonparkhurst  United States
Default Help Does This too
Does this one also have similar issue? If so, how to fix it. I may be way late to the game. Help Please
Jon
File Type: jpg Screen Shot 2013-10-28 at 10.45.04 AM.jpg (182.5 KB, 351 views)
Old 28th October 2013, 04:10 PM   #14
Zen Mod is offline Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
show us bigger picture of mains IEC inlet
mid pin (earth) must be connected to case
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa... by Mighty ZM
Old 28th October 2013, 04:30 PM   #15
hates ground loops
Rodeodave's Avatar
Any bare metal conductor between the mains input and the transformer is potentially life-threateningly dangerous. All such connections must be electrically insulated. And mains earth must be securely and directly connected to the metal chassis. Again, this is for safety reasons. All of this should not be taken lightly.
Old 28th October 2013, 04:35 PM   #16
It appears there is NO wire from the ground pin on the IEC inlet to anything? Anyone have a picture of the correct wire up for this?
I am not at home, so can't get a bigger image. But.. if I zoom, nothing to the ground..
JON
Old 28th October 2013, 04:42 PM   #17
Zen Mod's Avatar
pictures are everywhere , if you know what to look for
so - you need to solder proper wire to mid pin of mains IEC and to connect other end to bottom plate - best to solder eyelet on it , then screw to bottom plate
other two eyelets on IEC must be isolated - best with heatshrink , but if already soldered - make that with electrician isolating tape
to avoid hum problems , when amp is connected with (also safety grounded) source , you must have NTC of 10-15R between audio GND ( main gnd point on cap pcb) and case
NTC - search for CL60 ....... lemme try ........ here it is : http://www.ge-mcs.com/download/temperature/920_325a.pdf
after that - spread the word what piece of drek you paid for
Old 28th October 2013, 04:45 PM   #18
I found one. Thanks Guys.
Old 28th October 2013, 04:47 PM   #19
Zen Mod's Avatar
previous post edited
Old 28th October 2013, 04:51 PM   #20
hates ground loops
Rodeodave's Avatar
Recommended reading: Power Supply Wiring Guidelines
FS: Tim Rawson F5 clone ampHide this!Advertise here!
FS : complete First Watt F5 clone kit OliG Swap Meet 6 16th November 2011 12:37 AM
Tim Rawson BPA 300 Gainclone PCBs, Burr Brown DRV134PA, ect. saabracer23 Swap Meet 6 1st February 2010 04:08 AM
41HZ Amp6 basic built by Tim Rawson xecluded Swap Meet 5 8th August 2008 11:17 PM
