Swap Meet Sell your stuff here, who knows, some other fanatic might be interested!
Citation 12 complimentary Mosfet version PCB's
Old 6th October 2017, 03:47 PM   #21
kpsthakur is offline kpsthakur  India
Not able to find Kramskee...any chance to see the complementary mosfet schematic
Old 6th October 2017, 04:18 PM   #22
Tazzz is online now Tazzz
Citation12
Old 6th October 2017, 04:22 PM   #23
Originally Posted by Tazzz View Post
Thanks Tazzz, meanwhile, please check your PM
Old 6th October 2017, 05:37 PM   #24
schubert is offline schubert  United States
schubert's Avatar
Check this thread - you should be able to find all you need here, including info on Kramskee's boards.
Old 6th October 2017, 06:49 PM   #25
Very detailed...thank you...next stop parts...
Old 6th October 2017, 07:05 PM   #26
schubert's Avatar
Are you modifying an old amp or making a new one?
Old 6th October 2017, 07:15 PM   #27
Completely new one...looks like I could find most of the part...interesting values for few...from the schematic...for R1 it reads as 18K use 2.2mA CRD...not sure what that could be...also Tazzz mentioned to use ccs diodes at input differential to avoid thumps while power on...till now I have use 1M resistors pulled to ground at the input..not sure what would that be...any insight or part numbers would be helpful
Old 6th October 2017, 07:25 PM   #28
CRD = current regulation diode
It's to keep the input differential
biased and in controlled of the output until the rails are essentially depleted during turn off
Otherwise there is a large thump when the supply is slowly discharged
Old 6th October 2017, 07:27 PM   #29
schubert's Avatar
The part number from mouser for the CRD is given somewhere in the thread, I believe. If you can't find it I'll look for it when I get home. Tazzz's ccs diode is the same as the CRD. It does work, as my amps have no power-on or off thump.
Old 6th October 2017, 07:27 PM   #30
Thanks Tazzz, any part number I can refer to ...google did not lead me anywhere
Citation 12 complimentary Mosfet version PCB'sHide this!Advertise here!
Simulation - Pass MF-12 MOSFET Quasi Comp (Original) Modification for HK Citation 12 PB2 Pass Labs 49 5th April 2017 02:17 PM
Several of Q-s about Citation 12 MosFet argo Pass Labs 18 9th October 2016 03:52 PM
Simulation - Pass MF-12 MOSFET Fully Comp Modification for HK Citation 12 PB2 Pass Labs 0 10th May 2011 03:11 AM
Mosfet Citation 12 Sandor Pass Labs 2 30th January 2006 11:57 PM
mosfet citation 12 mr l Pass Labs 12 27th December 2004 03:22 AM
