HELP! High gain, low noise fet advice needed! - Page 2 - diyAudio
Go Back   Home > Forums > Commercial Sector > Swap Meet
Swap Meet Sell your stuff here, who knows, some other fanatic might be interested!
Closed Thread
Old 18th February 2002, 11:08 PM   #11
jam is offline jam  United States
jam's Avatar
Lenin
I do not think you will will get enough gain out of a two stage phono stage for a low output Ortofon. Noise will be a big issue. It will probably be ok with a high output MC.
Jam
P.S. Wayne at Pass Labs might be able to help. I suspect you will need a three stage circuit.
Old 19th February 2002, 06:55 AM   #12
Warp Engineer
On Holiday
AudioFreak's Avatar
Could someone please explain what is the difference between the different IDSS Grades.
Old 19th February 2002, 05:11 PM   #13
mlloyd1 is offline mlloyd1  United States
mlloyd1's Avatar
Default Japanese JFET IDSS grades answer
AudioFreak,
From the 2SK170 data sheet:
GR (Green) 2.6-6.5mA
BL (Blue) 6-12mA
V (Violet) 10-20mA
View the data sheet at a number of places; this is one that I like.
mlloyd1
Old 20th February 2002, 02:29 AM   #14
Warp Engineer
On Holiday
AudioFreak's Avatar
thanks, i couldnt find the datasheet before hence why i asked the question what's the go with that? have toshiba stopped producing these parts? for that matter, toshiva seems to have removed most of the datasheets for the small signal fets we commonly use.... surely they have not all been discontinued
UPDATE
I just checked back @ the toshiba site http://www.semicon.toshiba.co.jp/eng.../ft_mpsig.html and some of the datasheets are now present ... looks like they may have just been updating their site.... hopefully the rest of the datasheets will return soon...
Old 21st February 2002, 01:55 AM   #15
mlloyd1's Avatar
Default the order results are in ........
Originally posted by PH104
Hi Michael
If you buy them, please post what grade you get. I need a bunch myself, plus the J74 complement.
Phil
All:
My order came today. I ordered 20 each of:
2SK170, 2SJ74, 2SA970, 2SC2240
I got (drum roll please):
2SK170-BL
2SJ74-GR
2SA970-BL
2SC2240-GR
Note: I HAVE NOT checked all 20 pieces of each to see if any IDSS or HFE grade mixing occured. I will check later and let you know.
Certainly can't beat the price nor speed of delivery from MCM.
Thanks for the tip, Harry
mlloyd1
Old 21st February 2002, 02:57 AM   #16
Banned
Default Data sheets
Data sheets at:
http://site.pcmagazine.com.tw/audio/parts/parts.htm
H.H.
Old 21st February 2002, 03:08 AM   #17
PH104 is offline PH104  United States
PH104's Avatar
Hey Michael
thanks for posting the IDSS grades.
Looks like another order to them is on the way.
Oh - by the way - although Harry's a good guy, I first mentioned MCM.
Phil
PS - How's the THD analyzer coming?
Old 21st February 2002, 01:08 PM   #18
mlloyd1's Avatar
Sorry - Thanks Phil for the MCM tip.
Haven't started actually building the analyzer yet. Just going through my parts bin to see what I have and what I need. Also thinking about how I want to do the various range switching - relays versus multi-wafer rotaries kind-of-thing. Relays offer some benefits that could be useful. Also there were some updates that I want to look thorugh as well before I start.
I'll keep you guys posted as to progress.
Michael
Closed Thread
MingDa MC-7R noise and gain hirafu_boarder Tubes / Valves 79 1st March 2014 11:25 PM
Monica 2 + gain stage; High pitch noise problem spacemen12 Digital Line Level 0 27th October 2008 04:00 AM
high gain 2nd order high pass active filter topology sreten Solid State 21 23rd March 2006 02:26 AM
Help! High gain, low noise fet advice needed! Lenin Solid State 1 16th February 2002 02:53 AM
Copyright 1999-2017 diyAudio
