FS: AD 1862 N-J, 20-bit R-2R type D/A converter - diyAudio
Go Back   Home > Forums > Commercial Sector > Swap Meet
Swap Meet Sell your stuff here, who knows, some other fanatic might be interested!
Old 28th January 2013, 04:50 PM   #1
Vadim is offline Vadim  Canada
Default FS: AD 1862 N-J, 20-bit R-2R type D/A converter
I have 10 AD 1862N-J D/A chips for sale. They are left over from a DAC project. 16-Pin DIP Package. Its a great 20-bit D/A chip to work with. Excellent linearity and THD with a curent output.
$20US each. Please PM if interested.
Old 29th January 2013, 11:09 AM   #2
Nikitas is offline Nikitas  United Kingdom
Nikitas's Avatar
Could you share your project?
Old 29th January 2013, 11:59 PM   #3
Sure. A while ago, I built a 5 channel Dac for my Home Theater. There is a way to split the HDMI signal into 4 standard stereo SPDIF. From there you can build a multiple stereo Dacs as you see fit.
I chose to use a standard SC8416 for DIR and then I used ASRC from Analog Devices to up-sample to the higher rate. I used NPC 20-bit filter and some logic to invert the phase. Each channel used 4 AD1862 in a push-pull mode. I put most effort into an I/V converter, linear phase anti-aliasing filter and power supply. I tried to maintain at least 18-bit precision throughout.
AD1862 is a great chip; - you can trim it and actually see the LSB on the scope. I worked with more modern Sigma Delta Dac before and they were noisier. If I were building a DAC again, I would use 1862 before I go for 24-bit AKMs.
FS: UltraAnalog AES 20 and other parts for DAC project from NPC, Yamaha, AD. Vadim Swap Meet 0 19th January 2013 11:07 PM
Help with 6-Bit R-2R Relay Attenuator benproiii Analog Line Level 1 17th December 2012 05:58 PM
AD 1862 Eval board Zero Cool Swap Meet 0 3rd December 2011 01:08 AM
Denon DCD 1520 20-bit or 18-bit? beauty_divine Digital Source 0 9th September 2007 07:41 AM
Using 20 bit data with a pair of old 16 Bit DAC stefanobilliani Digital Source 15 14th January 2007 01:55 AM
Copyright 1999-2017 diyAudio
