Go Back   Home > Forums > Commercial Sector > Swap Meet
Swap Meet Sell your stuff here, who knows, some other fanatic might be interested!
Old 13th January 2013, 07:24 PM   #1
nicoch58's Avatar
Default Borbely Class A mosfet_Sales
The power stage is config for 16w Class A and then to 50w in A/B with my r-core 40Vac ,can be set for 25w in class A with 32Vac ,the bias can be set 600mA to up 1,2A with trimmer ,now is 0,9 A with 21°C up ambient
PSU Driver - 50VA toroid dual mono double diode(farchild stealth ) 2.000µF Nichicom Pass True gold 100V (total 4discrete bridge 4.000µ)
plus two dual mono Salas Shunt reg plus four 1000µ Pass True
The psu can be more simple ,ie only one trafo , without the shunt ,still separate psu driver/pw .....
preferred EU , shipping price goes up the thing is quite ....
One channel on pic
Sic58
Old 14th January 2013, 08:53 PM   #2
nicoch58's Avatar
the amp work fine as Erno stuff.... Is like new , used only some month the I switch to tube amp .
the driver stage note the dual jfet toshiba....all top notch component
please note my perfect build
Sic58
Old 14th January 2013, 09:47 PM   #3
nicoch58's Avatar
soldered with kester 44 and mundorf Ag on signal path
driver toroid and Salas shunt , power stage caps and diode
Sic58
Old 14th January 2013, 10:03 PM   #4
nicoch58's Avatar
Borbely Mosfet Output board with 3 pairs of lateral mosfets Hitachi Renesas 2SK1058/2SJ162.
Driver transistors for output power mosfets are medium power lateral mosfets 2SK216/2SJ79
Sic58
Old 18th January 2013, 08:05 PM   #5
Telstar is offline Telstar  Italy
Hi, do you have extra mosfets? both power and drivers?
Also pm me the details (in italian) of the PSUs since I dont clearly understand how are they made.
"The total harmonic distortion is not a measure of the degree of distastefulness to the listener and it is recommended that its use should be discontinued." D. Masa, 1938
Old 19th January 2013, 03:35 AM   #6
Price?
Grazie,
Davide
Old 19th January 2013, 07:41 AM   #7
nicoch58's Avatar
Davide PM send
Ciao
Sic58
Borbely I/V stage regal Swap Meet 2 17th October 2010 07:34 PM
Borbely Class A question astouffer Solid State 5 22nd February 2010 07:56 PM
FS-Borbely Class A mosfet nicoch58 Swap Meet 8 29th September 2009 09:45 AM
Borbely Cascode Onvinyl Solid State 25 10th September 2007 03:48 PM
Borbely DC-50 Class-A 20watts PassFan Solid State 5 6th January 2002 11:59 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd.
Copyright ©1999-2013 diyAudio
