FS in Los Angeles, beefy subwoofer setup, H-frames, full-range drivers - diyAudio
Go Back   Home > Forums > Commercial Sector > Swap Meet
Swap Meet Sell your stuff here, who knows, some other fanatic might be interested!
Old 15th December 2012, 12:14 AM   #1
taloyd is offline taloyd  United States
Post FS in Los Angeles, beefy subwoofer setup, H-frames, full-range drivers
Hello,
Have all the parts for a subwoofer project I was contemplating, but then realized I don't need such a beast.
Pieces!
Exodus Audio Tempest-X (not the X2) 15" subwoofer with XBL^2
Exodus Audio PR18 18" passive radiator, cast frame, mass kit
Pretty nice looking cubic box with one 18" cutout (was going to mount the subwoofer opposite the PR)
Asking $275 for the three components now that the plate amp is sold.
In other news:
Have a nice very compact Stewart PA-200B for $120 shipped. $20 less for local pickup in both cases. Was going to use for a bass guitar amp - but I already have one which works just dandy.
PA-200B is
90W RMS x 2 @ 4 ohms
50W RMS x 2 @ 8 ohms
200W RMS x 1 @ 4 ohms (yes, it's stereo 2 ohm stable - has a switch to lower rail voltage!)
Also have two nice large aluminum project boxes, with IEC power terminals and power switch. Can do $20. And two very small aluminum cases, with a flange mount, originally for building a pair of Hypex amplifiers into plate amps mounted on the speakers directly. Will get dimensions soon. $15 each for those. They're really nice.
Have a stereo LM3886 Gainclone amplifier in a rackmount case, nice Antek transformer, that popped the fuse last time I used it (was in storage prior). $40 for anyone who wants to play with it. Definitely local pickup only! I don't want to ship anything except for the QSC amplifier (it's really light) and the full-range drivers. Everything else is strictly local pickup only, thanks.
For pick-up in Los Angeles only:
Polk Audio MM120 subwoofers (one dead), excellent for dipole H-frames/etc.
$20 for the dead one (and it's 12" sealed enclosure) free!
http://www.polkaudio.com/products/mm120
T/S parameters:
Thiele / Small Parameters
Fs 30 Hz
Xmax Linear .3343 in / 8.7 mm
Xmax Mechanical 1.0 in / 25.4 mm
LE 1.3 mH
SD 514 cm^2
VAS 61L
QTS 0.47
QES 0.50
QMS 8.06
MMS 173.9
BL 15.5
CMS 164
Pe 500 W RMS
Cheers!
All the below are sold and are for reference only:
<<<<SOLD!>>>> Have a QSC PLX2-1804 pro-audio amplifier for a stereo subwoofer set up, 500/800 watts RMS at 8/4 ohms, with a quiet fan installed. $380.
<<<<SOLD!>>>> Have a pair of 1/2" plywood H-frames, with cast-frame JBL 15" MI-15A pro-audio woofers mounted on them for $120.
<<<<SOLD!>>>> Mark Audio CHR-70 (1st gen, gold cone)
<<<<SOLD!>>>> CSS FR125S
<<<<SOLD!>>>> And a cast-frame Goldwood GW-15PC-4 subwoofer for $40.
<<<<SOLD!>>>> O-Audio BASH 500W plate amp with parametric EQ
<<<<SOLD!>>>> Have a QSC MX700 amplifier , bought from a jerk who said it was fine. It is other than one channel not working. Good for parts, or if you only need one channel!
Last edited by taloyd; 9th September 2013 at 07:37 PM. Reason: things were sold, thankfully
Old 15th December 2012, 05:38 AM   #2
jmillerdoc's Avatar
How much for the CSS drivers?
Old 17th December 2012, 06:23 PM   #3
Post CSS FR125S
How's $60 including shipping? They're not too lightweight, as they have quite a magnet on them. Let me know, thanks!
-Tal
Old 17th December 2012, 10:51 PM   #4
katana2112's Avatar
How about the CHRs? Ship to 95386?
Aggressively Passive
Old 18th December 2012, 09:25 PM   #5
Pair of CHR-70 drivers tentatively sold!
Old 3rd January 2013, 05:19 PM   #6
Post bump
H-frames with JBL drivers sold, Goldwood subwoofer sold; everything else still available!
Happy New Year!
Old 20th February 2013, 01:34 AM   #7
Default updates
Updates on prices for full-range drivers:
Mark Audio 1st gen gold CHR-70s - $40 shipped
CSS FR125S - $50 shipped (they're kinda heavy)
2 x Polk Audio MM120 subwoofers, excellent for dipole H-frames/etc.:, $100 for the pair
(MM120 - Car Subwoofers | Polk Audio)
T/S parameters:
Fs 30 Hz
LE 1.3 mH
SD 514 cm^2
VAS 61L
QTS 0.47
QES 0.50
QMS 8.06
MMS 173.9
BL 15.5
CMS 164
Pe 500 W RMS
Ridiculous Exodus Audio/O-Audio/nice oak-style box setup is still available at $400. Still ridiculously potent.
Fantastic QSC stereo subwoofer amplifier (PLX2-1804) still available, 500/800 watts continuous into 8/4 ohms. Quiet fan installed. $375 picked up, $400 shipped.
cheers,
-Tal
Old 7th March 2013, 04:33 PM   #8
Post Updates
Updated to reflect sale of the full-range drivers. Intense subwoofer package still available, as is pretty much optimal stereo subwoofer amp (QSC PLX2-1804). 500W/800W continuous RMS is nothing to shake a stick at. Comes with heavy gauge Speakon-to-bare-wire cables to eliminate needing even that.
cheers,
-Tal
Old 28th March 2013, 11:02 PM   #9
Default O-Audio 500w plate amp available separately
O-Audio plate amp now available separately - $225 shipped CONUS.
cheers,
-Tal
Old 29th March 2013, 12:03 AM   #10
galyons is offline galyons  United States
PM Sent Subwoofer
Geary
FS: SB3 + Vortexbox, Los Angeles, $250 + shipping! taloyd Swap Meet 0 8th December 2011 12:29 AM
FS: Nice Oak Floorstanding Speakers in Los Angeles cuibono Swap Meet 3 7th May 2011 01:48 AM
FS IN LOS ANGELES: QSC PLX-1602 amplifier taloyd Swap Meet 4 15th April 2011 05:39 AM
FS: In Los Angeles: four 12" budget subwoofers taloyd Swap Meet 0 22nd October 2009 06:47 PM
FS: Energy bass cabinet (as subwoofer) for 2 x 15" in Los Angeles taloyd Swap Meet 0 23rd April 2008 01:13 AM
Copyright 1999-2017 diyAudio
