| Swap Meet Sell your stuff here, who knows, some other fanatic might be interested! |
Hey guys, I have a nice 3-way project for sale that I simply don't have time to finish. Along with the cabinet, baffle and drivers, I also have a crossover schematic generated from the actual measured data of each driver on the baffle.
Driver compliment: Woofer - Peerless Exclusive 830884 8" Mid - Tang Band 75-1553SE 3" dome mid Tweeter - SEAS 22TFF The measurements of all three drivers show incredibly low distortion in their working bands. I could even provide the working files for PCD simulation so that you could come up with your own crossover. What you get are the cabinets (PE 1cf in piano gloss), the custom cut baffle, the drivers and measurements. The 830884 is lightly used from a prototype effort a while back, but the 22TFF and TB mid are brand new, only tested. New, the 830884 Exclusive is around $85 if you can even find them. The TB mid is going for $135 each, and the 22TFF soft dome is $34 each. That's $500 worth of drivers alone. If anyone is interested in the entire setup, cabinet included, it could be yours for $500, and you'd be on your way to an amazing stand mount 3-way, and still be able to DIY your own crossover or use the one I designed myself from the measured data. Woofer: 4mH and 39uF Mid: 20ga 1.5mH inductor and 22uF in series and 4.7uF shunt. L-pad on the mid terminals of 12 Ohm in series with the mid and 7.5 Ohm shunt. Reverse polarity. Tweeter: 6.8uF, .25mH shunt, 18uF and L-pad of 4 Ohm series and 3.3 Ohm shunt. Reverse polarity. Send me an email if you're interested. pete_schumacher@yahoo.com Below are the measured plots including distortion. The "dip" at 400Hz is a boundary effect from an object nearby when the sweeps were taken. You can see it present in both the mid and woofer plot. Close mic sweeps show very smooth response from both drivers. ![]() |
#2 |
I'm all set, but I just wanted to say:
1) Those are nice looking! Those peerless drivers are classy 2) your measurements are not showing up |
#3 | |
If you like, I'll send them to your email, along with the simulated crossover that I posted. |
#4 |
I can see the measurements.
Show us what ya got at Homebuilt Hi-fi |
| Coils, caps, resistors, high quality, 4 sale | qquickk | Parts | 1 | 26th June 2010 04:23 PM |
| High quality amplifier power supply for sale | supernet | Swap Meet | 4 | 19th December 2008 10:22 AM |
| FOR SALE: New High Quality X/O Parts and Scan-Speak woofers | nelsondog | Swap Meet | 5 | 1st July 2008 03:08 AM |
| DIY high quality interconnectors? | space-cake | Parts | 4 | 28th October 2006 05:19 PM |
| High Quality DIY Loudspeakers | jteef | Multi-Way | 7 | 24th July 2001 12:53 AM |
