diyAudio
diyAudio (http://www.diyaudio.com/forums/index.php)
-   Swap Meet (http://www.diyaudio.com/forums/swap-meet/)
-   -   Wanted: Audax tweeter used in Vandersteen 2C (http://www.diyaudio.com/forums/swap-meet/221039-audax-tweeter-vandersteen-2c.html)
dgta 6th October 2012 06:47 AM
I need an Audax HD 9x8 D25 tweeter, used in Vandersteen 2C and some Rogers monitors.
Cal Weldon 6th October 2012 08:40 PM
Do you need the whole thing or just a new coil/diaphragm?
They sell them here if that helps:
Audax Tweeters, incl. TW025A0 ( HD 12x9D25 ), TW034X0, TW025M1
dgta 6th October 2012 08:58 PM
Cal, I only need the faceplate/coil/diaphragm.
That vendor does NOT have the HD9x8D25. I checked.
Edit: Sorry, my mistake. They do have just a replacement coil/diaphragm to be glued in the old faceplate. Not the same as the original, but I suppose I can just buy 2 for a balanced set. That will work.
Thanks much.
bigspeaker 6th October 2012 11:58 PM
Originally Posted by dgta (http://www.diyaudio.com/forums/swap-meet/221039-audax-tweeter-vandersteen-2c-post3191573.html#post3191573)
hi there i don't know if you still need this part but i bought a pait of veandersteen 2 speakers and i to need a tweeter i found the best way A if you don't have the old one is to recut the fave plat out of 1mm aluminium this is what was use the size is 90x90 mm i will post photos of the template i have all ready posted the crossover updates and drawings what you use for the tweeer is a VIFA 1 inch tweeter module that you glue behind the old or new face plate etc you have to put a 4.7 ohm 2 watt resistor in series with the possitive this is very important as it changes the tweeter from 4 ohms to 8 ohms the start freq is lower about 1,459 k thats fime more head room the polydax started at 5k more head room more detail hope this was a help i work as a sound technician :D:D
dgta 7th October 2012 03:42 AM
Thanks bigspeaker. I just ordered the replacement coil/diaphragm that Cal posted above so I'm all set. They're only something like $20 a piece so no need for complicated solutions :)
bigspeaker 7th October 2012 05:04 AM
Originally Posted by dgta (http://www.diyaudio.com/forums/swap-meet/221039-audax-tweeter-vandersteen-2c-post3192440.html#post3192440)
thanks my tweeters were missing when i bought my speakers can you send me the link to by the coil and if you come across a pair i am happy to buy 2 of the HD9x8D25
planet10 7th October 2012 05:25 AM
It is very possible that the Butterflies (that is what the dome/voicecoil assembly is called) can be had in North America. Many years ago i got some from Meniscus.
The butterfly is sandwiched between the magnet & the face-plate. Because they are keyed it is a REALLY easy repair.
dave
Cal Weldon 7th October 2012 05:40 AM
Originally Posted by planet10 (http://www.diyaudio.com/forums/swap-meet/221039-audax-tweeter-vandersteen-2c-post3192492.html#post3192492)
Great lunch Dave.
I know I'll never have the experience you do but aren't all dome tweeters with a replaceable diaphragm like that?
bigspeaker 7th October 2012 06:21 AM
Originally Posted by Cal Weldon (http://www.diyaudio.com/forums/swap-meet/221039-audax-tweeter-vandersteen-2c-post3192498.html#post3192498)
Great lunch Dave.
no it is a very special tweeter
dgta 7th October 2012 06:24 AM
Originally Posted by bigspeaker (http://www.diyaudio.com/forums/swap-meet/221039-audax-tweeter-vandersteen-2c-post3192481.html#post3192481)
Audax RW025A0 replacement voice coil for TW025A0 HD100D25 HD 9x8D25 from Falcon Acoustics, The Leading Supplier of DIY Hifi Components.
Resources saved on this page: MySQL 18.75%
