Wanted: Audax tweeter used in Vandersteen 2C - Page 2 - diyAudio
Go Back   Home > Forums > Commercial Sector > Swap Meet
Swap Meet Sell your stuff here, who knows, some other fanatic might be interested!
Old 7th October 2012, 06:42 AM   #11
Default thanks
now all i have to do is find the tweeters ebay time i think
Old 7th October 2012, 07:14 AM   #12
frugal-phile(tm)
planet10's Avatar
Originally Posted by Cal Weldon View Post
I know I'll never have the experience you do but aren't all dome tweeters with a replaceable diaphragm like that?
Pretty much. The comment was aimed at dgta's lumping of the faceplate in with butterfly (there are some drivers like that -- the VIFA and SEAS 19mm units for instance)
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 7th October 2012, 07:20 AM   #13
dgta is offline dgta  United States
Yes, Dave is correct. I did not realize the faceplate can be separated from the butterfly on the Audax. They are stuck together with some type of sealing/damping "goop" on mine so they appeared to be glued together. In fact they are not. They can be gently pried apart.
Old 21st October 2012, 05:49 AM   #14
Well, I ordered and received the parts from Falcon. They don't fit or look like the originals. So I'm still looking if anyone has a diaphragm or full tweeter.
Old 21st October 2012, 07:55 AM   #15
i too had this problem so i made some tweeter not successfully so the only joy i had was to find a tweeter which was used in the model 3's over all it is a better tweeter its round so you will have to cut a small amount off the top and bottom etc it starts at 8 ohms 600 hz to 20khz it aluminum dome much nicer this is the only replacement available i have been searching for 12 months now veandersteen will not help i have rang then so many time getting the runaround the tweeter is for sale on ebay not sure where you live the part number is DT500 you can also buy it from a company called WES Components in Ashfield Sydney NSW there phone number is 97979866 there open from 8.30 to 5.30 pm if you can't get them or find it give me a buzz you use PayPal send me funds i will pick them up post them giving you the cost for fast postage etc its a good idear to change all the caps on the crossover with poly caps your local electronics parts store should have the values 4.7uf 3.3uf
Old 21st October 2012, 04:39 PM   #16
Thanks bigspeaker but I am not interested in replacing with a different tweeter.
Old 23rd October 2012, 04:39 AM   #17
Epilogue
My experience with Falcon Acoustics was not a good one. The info on the website is incorrect.
There is, however, a simple way to redo the original Vandersteen (Audax) tweeters. I found it with the help of a local supplier. I am proving it out in the next few days. Anyone interested in the details PM me.
Tweeter / Mid Upgrade for Vandersteen 2CE bluepearl Multi-Way 7 8th October 2011 01:41 PM
Looking for Audax TMO25F1 Tweeter. Big_Bill Swap Meet 16 21st September 2009 07:06 AM
Vandersteen 2C replace fabric grill cloth skyhigh_ct Multi-Way 1 28th October 2008 12:19 PM
anything better than audax tweeter?? 4sfed5 Multi-Way 3 4th June 2008 04:47 PM
vandersteen 1c tweeter bonsai171 Multi-Way 1 12th June 2004 06:00 AM
Copyright 1999-2017 diyAudio
