diyAudio
diyAudio (http://www.diyaudio.com/forums/index.php)
-   Swap Meet (http://www.diyaudio.com/forums/swap-meet/)
-   -   FS: PLITRON single ended output transformers (http://www.diyaudio.com/forums/swap-meet/220515-fs-plitron-single-output-transformers.html)
Redboy 27th September 2012 03:15 PM
3 Attachment(s)
For sale is a pair of gently used Plitron PAT-3050-SE single ended toroidal output transformers. I picked these up recently and have since decided on a different set of iron for the amps in mind.
These are real beauties, potted in round cans. Great for your high end SE 300B or overkill 45 project.
Specs are the same as the current production PAT-3050-SE-02 model (see below), but without the 16ohm tap. The transformers for sale do not have a 16ohm tap.
From the Plitron site:
Product ID: PAT-3050-SE-02
13W Single Ended Output Transformer
PAT-SE range of single ended toroidal output transformers is especially suited for the 300B tube or its equivalents.
The primary impedance of this transformer is 5 kOhms and secondary impedances of 4, 8 and 16 Ohms. It has 13 Watts of power with frequency bandwidth from 20 Hz to 100 kHz. The differential phase distortion is less than three degrees up to 50 kHz.
Weight: 5.40 Kgs
Height: 177.8 mm
Width: 177.8 mm
Length: 177.8 mm
Asking $550 for these. Current list price for these transformers is $1,000/pr. + s/h from Canada.
Photos...
http://www.diyaudio.com/forums/attac...1&d=1348758589
Thanks.
Nate
Redboy 3rd October 2012 05:18 PM
Price reduced to $600, and still includes free shipping CONUS.
Redboy 10th October 2012 04:18 PM
'nuther price drop...
I'd like to sell these.
Price reduced to $550 or nearest reasonable offer.
If you're interested, drop me a PM.
limono 10th October 2012 06:40 PM
They would be perfect for Reichert's "Flash $ Blood" amp. Japanese are very found of those transformers and some prefer them to Tamura/Tango (but than , the grass is always greener....Have a bump on me ( I have Pat 3035 ;)
Redboy 23rd October 2012 08:09 PM
Still available.
Redboy 11th November 2012 04:32 PM
Now SOLD. Thanks.
Resources saved on this page: MySQL 18.75%
