Platter with bearing for diy turntable - diyAudio
Go Back   Home > Forums > Commercial Sector > Swap Meet
Swap Meet Sell your stuff here, who knows, some other fanatic might be interested!
Old 23rd September 2012, 08:26 AM   #1
j0nas is offline j0nas  Lithuania
Default Platter with bearing for diy turntable
I want to offer for diy turntables makers platter with magnetic bearing.
Platter is sandwich type made of two 15 mm. aluminium discs with 10 mm. acrylic insert. Thickness 40 mm.,diameter 320 mm., weight 7 kg. Has a conical hole for bearing spindle. On bottom side can be made ring with gaps ( in photos you see platter with 240 gaps ring ) for optic sensor of speed controller or rotation counter. Mat - natural leather.
Radial swinging ≤ 0,05 mm, vertical swinging of platter edge ≤ 0,2 mm.
As platter is not solid, has layers of acoustic different material, it has no resonances.
Bearing is classical type - a 9mm. steel shaft within a steel sleeve. The outer surface of the shaft and inner surface of the sleeve are precisely polished. Tip of shaft rests not on steel or ceramic ball, as usual, but on magnetic pillow, created by two neodymium magnets. This eliminates hard mechanical thrust between the shaft and bottom of bearing and reduces vibrations of platter. As diameter of magnets is only one inch and distance to tonearm is long, this does not affect the cartridge. The assembly is located in a 40mm diameter aluminium housing that is filled with oil. Length of bearing 90 mm. Flange diameter 100 mm.
Price platter with bearing 398 euro.
Jonas.
Old 23rd September 2012, 02:24 PM   #2
Cobra2 is offline Cobra2  Norway
DIY !
Cobra2's Avatar
Send a message via Skype™ to Cobra2
Nice!
You could maybe do mounting more flexible if the main-bearings had a fine thread/big nut?
Arne K
Don't believe everything you think...
Old 23rd September 2012, 02:45 PM   #3
Yes,this can be done
Old 25th September 2012, 04:21 PM   #4
You think the price is too high?
Old 25th September 2012, 07:27 PM   #5
DIY !
Cobra2's Avatar
Not really in the marked...before it becomes direct-drive ;-)))
Arne K
FS: Rega p2/p3 sub platter - bearing diy turntable dhole Swap Meet 0 13th October 2009 08:50 AM
DIY platter bearing cougarnut Analogue Source 17 9th September 2005 02:16 PM
DIY turntable bearing bigbulb Analogue Source 9 11th July 2005 02:16 PM
bearing assembly for DIY turntable wiggywag Analogue Source 0 8th May 2005 09:28 PM
FS: New Teres Turntable Platter and Bearing Assembly jdubs Swap Meet 0 23rd October 2004 09:22 PM
Copyright 1999-2017 diyAudio
