Janus Solo regulator PCB (mostly assembled) for sale. $35.00 plus shipping (less than retail.) Including printed documentation. (a few notes made in that.) This includes a high voltage rectifier section (5y3gt, solid state, or hybrid bridge) as well as the shunt regulator (12dw7/7247 tube)
I assembled and tested this for a line preamp and a phono preamp, it works great, but in one case I wanted line regulation, and in the other case I only needed the regulator not the rectifier, so I did it point-to-point. All parts included (stock) EXCEPT the following:
- 4 x 1uF film bypass capacitors
- 1 x 1.5k 5w resistor
