Swap Meet Sell your stuff here, who knows, some other fanatic might be interested!
WTB: pair of 2.0 mF inductors DCR < 0.35 Ohm
Old 12th August 2012, 05:54 AM   #1
Egindin is offline Egindin  United States
Default WTB: pair of 2.0 mF inductors DCR < 0.35 Ohm
I'm looking to buy a pair of 2.00 mF DCR < 0.35 Ohm inductors.
Old 12th August 2012, 03:48 PM   #2
Speaker Dude is offline Speaker Dude  United States
Air-core, solid iron core or laminated iron core?
Old 12th August 2012, 04:14 PM   #3
I'm not an engineer, but knowledgeable people - audiophile friends of my - insist that there are only two parameters for inductors - inductance and DC resistance. Everything else is pretty much the marketing hype and that Mundorf-Shmundorf types promote it and make a fortune of it. Who am I to argue with my irrelevant degree in Economics? I guess, air core or laminated iron core would be fine.
Old 12th August 2012, 04:28 PM   #4
theAnonymous1 is offline theAnonymous1  United States
theAnonymous1's Avatar
I would guess saturation characteristics are important too, but I'm not an engineer either and know little about speaker crossovers.
Old 12th August 2012, 04:36 PM   #5
Yes, saturation can be an issue. But, again, quoting my engineer friends, saturation only becomes an issue when you send hundreds, even thousands of watts into the speaker. Which, really, never happens in ordinary home hi-fi environment. And I never feel that my 16 wpc tube amp lacks power.
Old 12th August 2012, 06:38 PM   #6
Air-core has the lowest distortion but to get a 2mh .35 ohm air core will take a very large expensive coil. Big coils are also susceptable to stray magnetic fields from other inductors.
Solid core has the worst distortion - don't use it.
Laminate core is a good compromise, probably what you want.
Just go to Madisound Speaker Components: distributor of loudspeaker drivers and parts for speaker builders. and i'm sure you can find something close enough.
If not PM me and I can make one up for you.
Old 13th August 2012, 10:40 AM   #7
Moondog55 is offline Moondog55  Australia
Moondog55's Avatar
Do you mean milli Henry?/ mH?
2mH isn't a big deal,
2.20 mH 14AWG Foil Coil 0.42 ohms - CC2200/14 [4140] - $59.00 : SpeakerBug, capacitors, inductors, resistors, crossover parts, speaker supplies
2.20mH 15AWG Cored Inductor 0.15Ω DCR 5010 Induction Coil 15 AWG 2.20mH Cored [6660] - $17.50 : SpeakerBug, capacitors, inductors, resistors, crossover parts, speaker supplies
20mH on the other hand is huge
QUOTE" The more I know, the more I know, I know (insert maniacal laugh >here<) NOTHING"
WTB: pair of 2.0 mF inductors DCR &lt; 0.35 OhmHide this!Advertise here!
WTB 300VA 35-0-35 Vac toroid weskoki Swap Meet 8 15th October 2011 04:56 PM
WTB: Amp chassis with Conrad MF 35 151.5 heatsinks nicksgem10s Swap Meet 1 28th August 2011 05:33 AM
WTB: pair of 6.5-7" 2-4 ohm drivers Jimmy154 Swap Meet 0 21st May 2009 11:53 PM
DCR ratings of inductors Wamba-lam Multi-Way 6 4th August 2007 05:25 PM
Does the DCR of parallel inductors matter? Mos Fetish Multi-Way 4 3rd February 2004 10:43 AM
