| Swap Meet Sell your stuff here, who knows, some other fanatic might be interested! |
I am looking for 4 pcs NOS or used Shinkoh 100 kOhm / 2 Watts resistors to the anode resistor position in ONGAKU clone. I have AN Tantalums, but I would prefer Shinkoh ones. I am ready to buy also 1 or 2 pieces only if you have. I will pay shipping + PayPal fees too.
#2 |
Fat boys
#3 |
100 $ + shipping + PayPal for 4 pcs NOS resistors, please?
#4 |
Hificollective.com in the UK
SANTA |
#5 |
Just DIY!
100K Shinkoh is almost impossible to find these days...
You could however parallel 160K 1watt and 330K 1watt and it would give you ~107K 2watts. You can use a parallel resistor calculator online to figure it out. Parallel Resistor Calc http://www.1728.org/resistrs.htm Or use Audio Note Tantalum 100K 2watts and save you all the trouble and money! Ciao!
PREAMPs : AMB α10 + JC-80 clone | Balanced DCB1 | AMPs: AMB β24 | Aleph 5 | Symef | Hiraga | ML-2 | Fetzilla | Telos 390 Clone DACs : TPA Buffalo II + NTD1 I/V | TPA OPUS + IVY III Speakers : Jim Holtz Statements | Astasia SD | Tubasson Mark 2 Last edited by pinnocchio; 27th June 2012 at 07:06 PM. |
#6 |
Just DIY!
Just checked and they don't have 100K 2 watt or 100K 1 watt...
PREAMPs : AMB α10 + JC-80 clone | Balanced DCB1 | AMPs: AMB β24 | Aleph 5 | Symef | Hiraga | ML-2 | Fetzilla | Telos 390 Clone DACs : TPA Buffalo II + NTD1 I/V | TPA OPUS + IVY III Speakers : Jim Holtz Statements | Astasia SD | Tubasson Mark 2 |
#7 |
#8 |
680 & 390 are available in 1W. load sharing isn't optimal and the combination makes 107K, but that should not make a world of difference in this application i'd say..
SHINKOH-72867 SHINKOH-68362 and if i'd be willing to spend 100$ on a few resistors, i'd be willing to check out if the audible difference between 107K and 100K is worth the price. |
#9 |
The original Ongaku schematic we may find here http://www.enjoythemusic.com/magazin..._schematic.pdf
In the anode resistor position of the 1st half of the 5687 there are two pcs 100kOhm/2W per channel. They are working paralell (50kOhm/4W). So the minimum power what I need is 4W. This very signal position is quite sensitive for the final sound. I have same values of AN tantalum resistors, as we can see in the attached picture. Because of better and closer to the original Ongaku's sound quality I need Shinkoh ones. Used resistors are no problem. Btw thx for previous comments indeed. |
#10 |
Are you sure Kondo used Shinkoh resistors in the original Ongaku and that you are not attributing original status to Audio Note UK's after-the-fact version?
As I recall Audio Note was pushing those resistors. Personally I'd just lay a couple 2W Allen Bradley's in there. |
| WTB: Alps Blue Velvet (100Kohm), or fake | vrao81 | Swap Meet | 3 | 9th November 2011 06:06 AM |
| Shinkoh resistors needed | neazoi | Parts | 2 | 8th September 2009 07:20 AM |
| WTB: Shinkoh Tantalums (52k 1Watt) | ckniker | Swap Meet | 1 | 10th March 2008 05:40 PM |
| FS Shinkoh Tantalum Resistors | QSerraTico_Tico | Swap Meet | 1 | 22nd March 2007 07:02 AM |
| WTB: Shinkoh 2k2 ohm .5watt tantalum resistors | KT | Swap Meet | 0 | 15th April 2006 12:25 AM |
