Output board bal-unbal for symmetric DAC chips - diyAudio
Go Back   Home > Forums > Commercial Sector > Swap Meet
Swap Meet Sell your stuff here, who knows, some other fanatic might be interested!
Old 28th May 2012, 06:40 PM   #1
diyAudio Moderator Emeritus
jean-paul's Avatar
Default Output board bal-unbal for symmetric DAC chips
Hi I made several of these and used them with great pleasure on CS4397/98 DACs. They are better than the best opamp in terms of sound quality. They use Neutrik NTL-1 transformers that cost 55 Euro each. I want 80 Euro ex shipping for it.
It's only audio. Member of the non modular PCB design committee
Old 1st June 2012, 08:39 PM   #2
jean-paul's Avatar
bump
Old 28th July 2012, 06:15 AM   #3
jean-paul's Avatar
Not cheap but you can't beat a transformer output stage. If the chips I use now would be able to drive transformers I would still use them. No solid state solution comes close !
Old 31st July 2012, 04:13 PM   #4
jean-paul's Avatar
Are there no CS4397/8 users out there that want to experience the best this chip can deliver ?
Old 3rd August 2012, 02:13 AM   #5
Algar_emi's Avatar
Hi. Do you think I can use this board with the new ESS ES9023 DAC chip?
You can find the general datasheet on the net.
I bought a few and I want to build a few low cost dac around this chip, voltage output thought, no current. The transfo may not be the best match.
Let me know.
Old 3rd August 2012, 07:22 AM   #6
jean-paul's Avatar
You probably did not notice but Subbu and I developed a PCB for ES9023. You can see that one in the Group Buy section. I did not try the transformers on ES9023 as it does not have symmetrical outputs. I also use FN1242a and that one definitely does not like transformers so I will sell them.
BAL to UNBAL DAC buffer revintage Tubes / Valves 32 8th February 2010 05:08 PM
converting BAL to UNBAL using tubes and without transformers sunrise Tubes / Valves 101 24th November 2008 07:26 PM
PCM1804 bal/unbal adc meta Digital Source 14 7th February 2007 06:44 AM
Bal-Unbal-Bal Cable Wiring richie00boy Everything Else 3 3rd February 2005 11:08 AM
New TI chip unbal to bal markp Solid State 9 25th January 2005 08:16 PM
Copyright 1999-2017 diyAudio
