| Swap Meet Sell your stuff here, who knows, some other fanatic might be interested! |
#21 |
I completed machining and assembly on one enclosure, never finished the second one. I have the material but unless you have access to a machine shop it's pretty hopeless.
The front panel is completed with the exception of the front knob recess. I think there is a Q&D fix for this. All that is needed is a drill press and the right bit. Your enlosure looks very nice except for the front panel so I wouldn't mess with that. You could probably fininsh it off with a perforated Al cover painted black. Are the trafos so close to the low level circuitry giving you noise problems? |
#22 | |
True, true. It helps to have a (soon to be) spouse that appreciates the gear as you do and also is OK with the fact that you will keep parts around the house (well maybe in just one part of the house) sometimes for "a while" (could be years) before they (if ever) get used.
IME, WAF doesn't only apply to completed gear. mlloyd1 who has stories to tell Quote:
#23 | |
No, these are toroids and their magnetic fields go through the center (up and down) and do not impose on the low level circuitry. The amp is silent with respect to noise, even at high volume. I know someone that has a bridgeport machine that can drill metal. I wonder if it can be used to cut. How many cut out front panels do you have? Were you planning on making kit enclosures for the APOX and it fell through? Your enclosure on the Apox thread looks good. So does Peter Daniel's using that old stereo. |
#24 | ||
It is a coil wrapped around itself. Anyway,it's great that you don't get noise, all you have to work on is front panel Quote:
The deal I had was to design and build two enclosure one for me and one for the guy that had access to machines but didn't know how to use them. A painful experience I am not going to repeat in the future. Fortunately, in the end I got mine done. It came out great and I am very happy with it. I haven't had time to finish the whole project, yet. |
#25 |
Hi Grataku,
I lost my job and have been struggling to keep my family going... Dale |
#26 |
Just wanted to chime in about replacing the front panel...
What I'd do, personally, with that, is just get a small piece machined to sit on top of the LCD, covering the exposed circuit board and wiring. Your display doesn't necessarily have to be mounted flush with the front panel, after all. Just get a small piece made to tidy it up a bit and it'd be fine. |
#27 | |
Hi Harvardian, I'm in the same position as you are. I wish you all much strength and don't give up, eventually, you'll succeed! All the best! Audiofanatic
Be nice to animals. |
#28 |
You have mail!
cheers vsr |
| Fs Aksa 100 | bacworth | Swap Meet | 4 | 5th December 2005 10:33 AM |
| AKSA 55W and GK-1 | harvardian | Swap Meet | 4 | 15th October 2003 08:08 AM |
| New AKSA 55 | ultrachrome | Solid State | 13 | 16th June 2003 02:00 AM |
| Page generated in 0.09395 seconds (81.34% PHP - 18.66% MySQL) with 11 queries |
