1. Product: JL 1000/1 v2
2. Specs:
@ 4 Ω: 1000 W RMS x 1
@ 3 Ω: 1000 W RMS x 1
@ 2 Ω: 1000 W RMS x 1
@ 1.5 Ω:1000 W RMS x 1
Frequency Response: 5 Hz - 250 Hz (+0, -1dB)
S/N Ratio, referred to highest rated power: >95 dB below rated power (A-weighted, 20 Hz - 20 kHz noise bandwidth)
S/N Ratio, referred to 1 W (Main Channels): >65 dB (A-weighted, 20 Hz - 20 kHz noise bandwidth)
Damping Factor @ 4 Ω: >500 / 50 Hz
Damping Factor @ 2 Ω: >250 / 50 Hz
THD+N @ Rated Power (Main Channels): <0.05% @ 4 Ω
Input Voltage Range @ RCA Inputs: 200 mV - 8 V RMS
Min Copper Power / Ground wire Gauge: 4 AWG wire
Fuse Rating: 100 A (AFS, AGU or MaxiFuse™)
3. Description/Condition: kinda scratched up i would give it a 7/10 cos 10/10 mech
4. Price: : lets start it off at $350 plus ship only trades he wants would be for a crescendo bc 2000 or db drive a7 2000.1
5. Pictures:
Pictures are a few days old...but..
2. Specs:
5. Pictures:
Where are you located? Would you take $250 + shipping? I know it is a little low but the amp looks quite scratched up. I would say that from the pics the cosmetics look more like a 5-6/10. If you have some better pics that show it is in better condition could you post them?
I know you say you are looking for only those two other amps but is there any chance you are looking for a head unit, components, 4 channel amp or subs?
The crescendo BC2000D is the best bang for the buck if you have the electrical system to support it. Looking at your sig I am guessing that the XS power is your second battery and that everything is 1/0g, is that correct? Are you planing on using an amp that big on some audiobahns? If so you might be better off upgrading your subs or building a box that is more efficient.
