WTB: Pro (Hi-eff) woofers - diyAudio
Go Back   Home > Forums > Commercial Sector > Swap Meet
Swap Meet Sell your stuff here, who knows, some other fanatic might be interested!
Old 10th April 2012, 02:25 PM   #1
beeah is offline beeah  United States
Default WTB: Pro (Hi-eff) woofers
I'm looking for a pair of LF drivers with the following characteristics:
  • fs < 40Hz (lower the better)
  • dB/1W/1M > 96 (higher the better)
  • Qts ~= .3 (give or take, within reason)
  • $ < 100/pair incl. shipping
  • fully functional
  • able to crossover at at least 800Hz, preferably 1200Hz
Basically, a driver for a large (~4-6 cu. ft.) BR cabinet to be mated with a compression driver on an Altec 511B via an active crossover.
e.g.:
Dayton PA380-8 <== hint hint
Eminence
MCM
Old 10th April 2012, 04:01 PM   #2
hatrack71's Avatar
I have a pair of McCauley M1520 15"ers if interested. Not sure they go much lower than 45 Hz free resonance though. These will be $200 for the pair or a cool trade will take them. They are heavy as hell
Old 10th April 2012, 04:30 PM   #3
I'm afraid they won't dig nearly deep enough... Thanks for the reply.
Old 10th April 2012, 04:37 PM   #4
Hey, I am looking for something simliar, only >90dB @ 1W, 8 ohms nominal, and in an 8" or 10" diameter. I'd like to use it as a woofer, so Xmax >=5mm would be nice, and Fs < 40Hz. This seems to be somewhere in-between home audio and pro audio driver offerings.
-Charlie
Old 10th April 2012, 06:48 PM   #5
-Charlie
http://www.parts-express.com/pe/show...number=290-290
Old 10th April 2012, 07:58 PM   #6
GordonW is offline GordonW  United States
GordonW's Avatar
So, basically, to recap- you're looking for a 15" woofer that will give around 96dB sensitivity in a 4-6 cubic foot cabinet? With those parameters, you can reasonably expect about a 36 Hz f3 point, with a vented box (6 cubic feet- for smaller box, you'd have a higher f3 or lower sensitivity).
If you're expecting more low bass extension than this, you either need to accept a larger box, or lower sensitivity. Hoffman's Iron law is, well... iron.
Gordon.
Speaker Design, Restoration and Repair- since 1985.
Old 10th April 2012, 08:49 PM   #7
The box is a function of the driver. I need to define the driver to determine what the box is. Yes, an f3 of 36Hz is roughly what I expect to get.
I'm living with Cornwalls now, so a box > 6 cu. ft. isn't a concern.
Are you suggesting a different route? I'm pretty set on a two-way configuration.
Old 10th April 2012, 10:46 PM   #8
I have a pair of MNNce Alpha 15's, excellent condition. Specs & pricing would be "close" to what you're looking for. MAYBE trades. Let me know. Thanx.
Old 10th April 2012, 11:41 PM   #9
Originally Posted by beeah View Post
Ewwwww... I usually stay away from that particular brand. Matches specs, however.
Old 10th April 2012, 11:46 PM   #10
Illusus is offline Illusus  Canada
Illusus's Avatar
I'm in the same boat. Two way with Altec 902 on CD waveguide and 15" woofer. I had a pair of JBL E140 and 12" waveguides so I built the cabinets around them but tuned for JBL 2226, now I can't find 2226s at a reasonable price...well I can but my wallet is unreasonably thin. I'm selling off everything I can. E140 sounds great but has very little output below 50Hz. I like bass.
Fighting the program since 1976.
WTB pair of 12" mid bass hi eff, SoCal preferred mikeford Swap Meet 17 3rd July 2012 08:30 AM
Pro woofers carbon fibre cone lduarte1973 Multi-Way 14 16th November 2011 05:57 PM
WTB: Vifa P22WP-01 Woofers (surplus 8" Mackie woofers) gtforme00 Swap Meet 9 3rd June 2008 10:57 PM
Why are the diaphragms of pro woofers always made of paper? 454Casull PA Systems 27 16th December 2007 07:52 PM
Pro audio woofers with no gaskes eRiCdWoNg Multi-Way 1 10th April 2004 06:50 AM
Copyright 1999-2017 diyAudio
