Selling my two 2x60W gainclones for USD 1000.00 each. Comes with 230V/50Hz power supply. See pic at http://thomasb.freewebspace.com
/Thomas B
/Thomas B
I would rather suggest upgrading with few pairs of monoblocks
http://www.diyaudio.com/forums/showthread.php?s=&postid=242279#post242279
I'm afraid that if stereo amps can't drive Apogees, the monoblocks will face the same problem. Technically, monoblocks are the same amps, just the envelope is pushed further, by exploring different aspects of chassis design and integrating PS, which IMO is a better thing, if done properly.
mFinalHeaven said:Holy crap, those are some nice looking amps you guys got there. I haven't been keeping track of the chip amp forum much. WOW!! Can you guys tell me where you guys get the parts to make the case so nice like that or is it in some thread or link somewhere. thanks.
Both amps were built by hand using old method of tries and errors. The only tools used were drill press, belt sander and band saw. The parts used are standard size flat bars 2 x 0.5 and 3 x 0.25 and aluminum square tubing. Some insight can be found in this thread:
http://www.diyaudio.com/forums/showthread.php?s=&threadid=3981&highlight=
If anything would be on transformer's side, it would be bridges, but then the assembly would be more complicated. I like the simplicity of connecting caps to bridge PCB by using caps' leads. One way to avoid interference was shielding the chip with copper bar, which also improve heat dissipation. The caps have to be right by the chip, for better performance. Everything is attached by O-ring rubber and some double sided tape on bottom (the type used in stores for security sensor devices). This way the coupling is soft and less vibration transfered to the capacitors and the chip. The copper bar acts as one big damper and rests directly on a cone, which further improves vibration control.jam said:Peter,
Great looking amps. I wonder if yoo have tried putting the filter caps and bridge on the other side of the center shield ? It might make it even quieter. It was a great idea to have the ac in at one end and the audio in/outs at the other.
Jam
The brass bar, which acts as rear footing has tremendous influence on sound. I tried to add neoprene pads and the sound changed substantially.
Peter, your monoblock design is impressive as hell. Makes me wanna do away with my Apogees and use normal speakers instead. The Totem Model 1 Signatures were magical when driven with your original gainclones. Makes me wanna go for five of these Totems with five of your monoblocks. Is it possible to put five copper subassemblies/five transformers in one case and get a five channel gainclone multichannel amp?
Peter, thanks for the options. I will think about it. But I really start to like the idea of five Totems driven by five monoblocks. Would be nice if each monoblock could be encased in Ripac Cassettes as on the pic. These could be inserted in a rackcase, as Mark Levinson did with his Cello gear.
