diyAudio
diyAudio (http://www.diyaudio.com/forums/index.php)
-   Swap Meet (http://www.diyaudio.com/forums/swap-meet/)
-   -   FS: 1KW tapped horn sub and 700W amp (http://www.diyaudio.com/forums/swap-meet/209012-fs-1kw-tapped-horn-sub-700w-amp.html)
andyboy 17th March 2012 01:16 PM
Tapped folded horn built to Walter's plans from Speakerstore.
Loaded with Ciare 12.00 SW.
Full working order, has only seen use as a home cinema sub. Paint finish is ok, looks fine from a few feet away but has a few runs (beer didn't help when re-painting it....). Also the speaker/volume icons on the front were done in glow-in-the-dark paint, which doesn't glow as much as I hoped, and also looks a little blotchy. Wouldn't be too hard to cover up though.
I also have a JBSystems AX700 amp, and a few meters of high-power speaker cable with speakon connectors on one end and 1/4" jacks on the other.
Cabinet is approximately 18 inches * 18 inches * 6 feet tall.
It is amazing as a home cinema sub, and adds a massive amount of oomph to almost any music. I use it with a low pass filter set at 80Hz.
Driver + cabinet: 150
Amp + cable: 40
I would prefer to sell it as one lot.
I'm in South Wales.
Edit: changed price.
http://i243.photobucket.com/albums/f...-19-00_958.jpg
http://i243.photobucket.com/albums/f...-19-18_189.jpg
http://i243.photobucket.com/albums/f...-19-49_281.jpg
http://i243.photobucket.com/albums/f...-19-09_531.jpg
Resources saved on this page: MySQL 18.75%
