| Swap Meet Sell your stuff here, who knows, some other fanatic might be interested! |
SOLD: Salas SSHV1 shunt reg FULL BUILD!
Up for sale is one of my Salas shunt regs... perfectly suited for line stages, headphone amplifiers or anything else that consumes around 65mA max. Can supply a range of 150 -275V approx., current set resistor is socketed to easily adjust current to the desired value. Tested and ready for use! The best regulator for ultra low noise, very high bandwidth and ultra low output resistance... see the threads on Diyaudio! Needs rectified and filtered DC in of about 20V more than the desired Vout. Only very good parts used throughout incl. premium Jantzen Superior-Z caps for the critical positions (a 50$ value itself). Heatsink and custom made adapter included. Asking 85$ excluding shipping. Shipping worldwide, though expensive across the ocean ![]() Shipping to Europe pls. ask (options available) http://s1.directupload.net/images/us...0/wpclehi5.jpg http://s1.directupload.net/images/us...0/94ddshn9.jpg Last edited by Stixx; 15th March 2012 at 08:37 AM. Reason: see above |
#2 |
Hello stixx,
Is it ready for the tube-i-zator pcb, or can you put it ready for the tubr-i-zator pcb? If yes, i can give you the 85 dolars "including" shipping costs to Portugal. Best regards |
#3 |
Hi Cabaco,
I don't know the Tube-i-zator pcb very well, but when it is a tube output stage you can sure use the Salas shunt. Do you have a schematic of the Tube-i-zator? Then I could check to be sure how to connect it. I am using the Salas shunt in two of my headphone amplifiers (Aikido parafeed and SE with output transformers), and they sound fabulous! Please send a PM with your email adress! Obrigado Oliver |
#4 | |
What are they called? thanks David |
#5 | |
It looks like he used Breakable Header Sockets. I did a google search |
#6 | |
#7 |
PM sent.
Best regards Rui Cabaço |
#8 |
bump
| FS : 2 x Salas low shunt Group-design by Salas | korben69 | Swap Meet | 7 | 9th November 2011 10:06 PM |
| Salas shunt help | agithegreat | Power Supplies | 19 | 27th July 2011 02:24 PM |
| Salas low shunt Group-design by Salas | quanghao | Group Buys | 785 | 31st May 2011 05:48 PM |
